Can't seem to create SD card
After repeated attempts I have been unable to create an SD card for my PINE64
Pheonix card gives some weird error, So tried WindiskImager it fails.... Pulling my hair out.
Using Windows 10 PCs
FYI I have been able to create bootable cards for multiple Pi's, PCDuino's and others without a problem
(06-25-2016, 07:27 PM)blanius Wrote: After repeated attempts I have been unable to create an SD card for my PINE64
Did you check the md5, maybe your file is corrupted. Try downloading a new image
What is this weird error exactly ?
Also make sure that you dont try to create a card with Phoenixcard using dd images, or using dd/win32diskimager/etcher/pibaker with Phoenixcard images...
hmm. there are two different download pages, one from the main page and one from the Wiki. The Wiki has more choices. Perhaps this is were I went wrong.
The main Downloads link (https://www.pine64.com/downloads) brings :
Ubuntu Linux Image [20160501] based on Longsleep build, updated by Pine64
Suitable for 1GB/2GB Pine A64+ Board, not suitable for 512MB Pine A64 Board due to system memory constrain
MD5 (Zip file) : DD86E696848C404D48BEFD4A24B8B111
File Size: 1.91GB
Included XFCE Desktop, Midori Browser, Thunder Email, LibreOffice Suite, and Gnome MPlayer
Download Here
Login with
username: ubuntu
password: ubuntu
Android 5.1.1 Image Release 20160428 [BETA]
DD image for 8GB microSD Card:
MD5 (Zip file): B1C7C22A28DCFDE485099B885C946052
File Size: 1.1GB Download Here
Rooted DD image for 8GB microSD Card:
MD5 (Zip file): 9C1AC73BD0794EFFB67C90A46D74B6E5
File Size: 587MB Download Here
Remix OS 2.0 Image Release 20160415 [BETA]
Suitable for 2GB Pine A64+ Board, can runs on 1GB Pine A64+ Board with performance lagging, not suitable for 512MB Pine A64 Board
MD5 (Zip file): efeb178d28593d4d928f70c8506953a4
File Size: 1.2GB Download Here Torrent Download
Where as link at the bottom of the page (http://wiki.pine64.org/index.php/Pine_A6...re_Release) has more, I did not see the DD part so trying again.
Now Pheonixcard shows success but the SD card is still blank when done. And putting it into the PINE does nothing.
Shouldn't be this difficult
Well looks like this thing will take it's place on the shelf with the other non-functioning boards. At least until there is a way to put an OS on it.
(06-26-2016, 06:41 PM)blanius Wrote: Now Pheonixcard shows success but the SD card is still blank when done. And putting it into the PINE does nothing.
By blank do you mean that Windows does not recognise the content of the microSD card? If so, this is because Android (and Remix and Ubuntu, I believe) uses an ext4 file system, which is not natively recognised by Windows and so the card will appear to have nothing on it.
Inserting the card into the Pine64, you should get some result, though. So it may be a power or video issue, rather than a microSD card issue.
Shouldn't be power issue as I'm using the supply from my Lattepanda. They provide a very good usb power supply and cable with their hoard. I do have one Linux computer here I can try to create the card with. I've made quite a few sd cards for pi and pcduino without issue using windiskimager
I've had no problems creating both linux and android images using win32diskImgr. I was going to try the phoenix card tool but have yet to see a need to do so.
If you've had no problems creating other images, I'd suspect either a corrupted download, or something going astray as you extract the image.
  How to boot from SD card on pinebook pro linux123 3 6,076 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 4,467 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,377 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,463 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 212,946 03-03-2020, 11:34 PM
Last Post: siyatalerja
  eMMC card on adapter Malmgren 8 11,230 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 10,076 02-08-2017, 05:42 PM
Last Post: maxpayne
  recommended micro sd card? Gustavo Woltmann 1 3,606 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 3,678 11-03-2016, 02:33 PM
  SD card burn img size problems stephen0205 17 23,523 09-22-2016, 06:28 AM
Last Post: tkaiser
