How to restart the modem on Arch
(10-21-2021, 03:40 PM)lacriz Wrote:
if [ -e /dev/ttyUSB2 ]
   echo "modem works"
else
   echo "modem does not work, restarting now ..."
   sudo killall ModemManager
   sudo /usr/bin/ModemManager &
fi
I would stop/start or restart ModemManager via systemctl since it's already integrated by the system as a systemd service. Now you are circumventing the service with unknown consequences (unless you checked how ModemManager.service is configured). It's much cleaner if you interact with the service and not the utility itself.
Your phone always crashing in deep sleep is a much bigger problem though that I would investigate. I don't have anything off the top of my head, but I would check what happens in the logs with journalctl or dmesg.
(10-22-2021, 01:44 AM)kqlnut Wrote: Your phone always crashing in deep sleep is a much bigger problem though that I would investigate. I don't have anything off the top of my head, but I would check what happens in the logs with journalctl or dmesg.
Thank you; in my mind these 2 problems are about equally bad Smile
I followed your advice, maybe you can help? Seems I have a problem with some swap partition?
https://forum.pine64.org/showthread.php?...#pid101859
PS
You are right of course about how I should restart the ModemManager service. I will follow-up on that Smile
  Updating Arch Linux _radv_ 8 823 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,249 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 780 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,945 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,865 10-06-2023, 09:36 AM
Last Post: luppivega
  Modem Issues SchizoPinePhone225 2 831 08-31-2023, 08:23 PM
Last Post: SchizoPinePhone225
  Remove modem firmware aular 10 1,972 08-23-2023, 05:53 PM
Last Post: aular
  Arch with FDE user641 1 908 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 849 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 2,142 11-07-2022, 04:38 PM
Last Post: Ferriah
