screen doubling
hi...just received my new phone..right out of the box every image and character is doubled (a sort of wobbling mirror image just next to the original one) so its very hard to see and select anything at all...tried several distros...all have the same problem ...its everywhere whatever I try to run...so would this indicate a hardware issue?...the screen or its connections?.....disappointing if so as its brand new......or perhaps there is something I can do to fix it?
At a bit of a loss and haven't even crossed the start line yet!
thanks for any clues....
If this affects the whole screen (not just individual elements on the screen) and happens with every distro in the same way, it sounds like a hardware issue. You could open the phone and reattach the screen connector, see if that helps. Otherwise open a support ticket and have the screen or phone replaced under warranty (don't miss the deadline).
(10-01-2021, 05:19 AM)ommm Wrote: hi...just received my new phone..right out of the box every image and character is doubled (a sort of wobbling mirror image just next to the original one) so its very hard to see and select anything at all...tried several distros...all have the same problem ...its everywhere whatever I try to run...so would this indicate a hardware issue?...the screen or its connections?.....disappointing if so as its brand new......or perhaps there is something I can do to fix it?
Please submit a support ticket at https://support.pine64.org and post the photo snapshot. If this is the hardware issue, support team will RMA.
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,182 08-28-2023, 11:38 AM
Last Post: fxc
  locked out on PIN screen g40 1 636 06-07-2023, 10:20 PM
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,256 02-03-2023, 01:27 AM
Last Post: dante404
  My screen bottom side has loosed its tactile function arbocenc 1 804 01-06-2023, 10:02 AM
Last Post: britelite
  "PinenotePhone": Swap E-Ink Screen Onto Pinephone? britelite 0 660 01-03-2023, 06:17 PM
  Screen seems ok but no display UncleMeat 3 1,583 11-03-2022, 07:02 AM
Last Post: fxc
Question Black screen no matter the OS joseph303 2 1,475 07-19-2022, 01:07 AM
Last Post: joseph303
  Boot problem: wrong screen orientation Jetpac 6 3,770 07-18-2022, 12:47 PM
Last Post: fravoi
  Manjaro phosh no screen rotation sandspur 1 1,315 06-23-2022, 01:02 AM
Last Post: rapp
  Screen Lock Dinosaur1946 0 816 05-03-2022, 05:03 PM
Last Post: Dinosaur1946
