Quartz64 Model-A 8GB board boot error
Hello. I've got my Quartz64 A 8GB today and tried to boot with several Linux-based and Android images. I've tried both mmc and emmc boot with the same result:
DDR Version V1.07 20210419
ln
ddrconfig:7
DTT cs0 error
L3952:reinit fail
LPDDR4X, 324MHz
error
ERR
Any suggestions what this failure is meaning?
Does it expected at the moment for this board version?
Do you have the BAT_OFF jumper in place?
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(09-26-2021, 11:42 AM)CounterPillow Wrote: Do you have the BAT_OFF jumper in place?
Tried both on/off with the same result.
The jumper should be in place, i.e. the "off" position.
Can you try booting a non-Android image? Try the pgwipeout CI image: https://gitlab.com/pgwipeout/quartz64_ci...s/download
Unzip it, flash rk3566-quartz64-a.dtb.img.xz, e.g. as follows (with /dev/sdx being whatever your SD card or eMMC module is.
sudo -i
cd /path/to/artifacts
xzcat rk3566-quartz64-a.dtb.img.xz > /dev/sdx
Once it finishes, try to boot it with UART attached. You should get an u-boot menu that allows you to boot a Debian installer. Just try booting into it, if it works we know the board's good. It's possible that whatever Android images you're using are not actually using recent enough firmware for the board. (It looks like memory training is failing?)
Plebian GNU/Linux
Thanks for your suggestion. However I've tried some of the recent versions images as well: crux, slackware, Manjaro.
With `pgwipeout` I have a bit different error:
    DDR Version V1.10 20210810
    ln
    unknown device
    error
    ERR
I suppose you have a chance to test it with 8GB version successfully before?
PS My device has following marks: Quartz64-3566-V2.0 from 2021-04-27
(09-27-2021, 04:43 PM)d4s Wrote: I suppose you have a chance to test it with 8GB version successfully before?
Yes, I'm using the 8G version. Same date code as well.
Plebian GNU/Linux
Just to keep it here: support team confirmed that my board has boot error and will be replaced.
  No boot...power light shows green 98cwitr 2 1,674 01-19-2024, 07:31 PM
Last Post: Darin755
  Quartz64 seeming died Darin755 0 132 01-19-2024, 07:29 PM
Last Post: Darin755
  Quartz64B eMMC boot failure bsmorgan 2 489 11-15-2023, 12:00 AM
Last Post: balbes150
  Quartz64 model a neither booting nor resetting without pressing reset button aleix 2 1,143 08-24-2023, 04:52 AM
Last Post: aleix
  Thoughts on repairs for a Quartz64-B beepy 1 762 08-02-2023, 05:02 PM
Last Post: beepy
Question Li-Pol QUARTZ64 Model-B vs Model-A polrus 1 737 07-13-2023, 10:36 PM
  can't get quartz64-A working jyoung 14 4,332 04-29-2023, 04:41 PM
Last Post: diederik
  Trustzone support for QUARTZ64 capablegh 13 6,886 04-28-2023, 01:58 AM
Last Post: NCLI
  Booting Quartz64 Model B Jojo120120 14 7,467 01-23-2023, 03:31 AM
  quartz64 model b 2x20 max power proj964 1 1,520 10-23-2022, 05:32 AM
Last Post: CounterPillow
