axolotl signal client on postmarket os?
I'm using axolotl on my pinephone with manjaro. There is no arch/manjaro version from axolotl, but it is repackaged from the mobian .deb package.
See here: https://forum.pine64.org/showthread.php?tid=14223
and here: https://github.com/nuehm-arno/axolotl-mobian-package
Is it possible to build a apk package from source or "repackage" one of the existing packages from other distros?
(09-17-2021, 02:10 PM)nieral Wrote: I'm using axolotl on my pinephone with manjaro. There is no arch/manjaro version from axolotl, but it is repackaged from the mobian .deb package.
Hi nieral,
It is a bit late for my reply, I do not know any build of apk package for Signal, but I only read online one successful case for pinephone to run Signal on postmarketOS successfully:
https://www.reddit.com/r/PINE64official/...e_success/
You can try flatpak for axolotl, this is the closest one you can get from a packaged one for postmarketOS. However, I tried to install it but it is always stay on pending.
I did get Signal to run on anbox, using duckduckgo browser to download Signal and installed it and run, but anbox is responding slowly and crash often, and the keyboard sometime is not responding.
Hi nieral,
Thanks for the reddit link! I will take a closer look at this solution. I tried signald in connection with pidgin in the past. But with pidgin I had issues with the keyboard. Therefore Axolotl was a relief (at least at my pinephone with manjaro).
  Software app in postmarket gnome shell Uturn 1 583 09-06-2023, 05:27 AM
Last Post: alaraajavamma
  Issues after installing latest PostMarket OS with POSH xen314 4 1,324 08-20-2023, 11:18 PM
Last Post: xen314
  Postmarket os printer setup Chief 3 2,155 01-21-2023, 04:27 PM
Last Post: jojuma
  Build signal-cli uby89 2 3,738 07-25-2021, 10:23 AM
Last Post: uby89
  No camera app on PinePhone Postmarket Edition / Phosh Noah222 3 4,851 12-02-2020, 03:38 PM
Last Post: jmorris
  Email client p1trson 1 3,013 11-22-2020, 06:34 PM
Last Post: hiimtye
  Initial thoughts, PinePhone PostMarket edition. plainenough 28 32,133 11-18-2020, 03:43 AM
Last Post: eKeith
  Resize apps for postmarket OS zeb11 8 10,576 09-26-2020, 04:21 PM
Last Post: ragreenburg
  Signal on PostmarketOS GloriousCoffee 8 11,818 09-01-2020, 07:37 AM
Last Post: nieral
