How do I even turn that thing on?
Just letting you know, this is how my adapter labels like:
[Image: IMG-20211206-210246.jpg]
[Image: IMG-20211206-210338.jpg]
So if I'm not mistaken, red in pin 6, blue in 10, USB in PC, power the board on, screen command, and then black in 8?
Or blue and black in reverse order?
Because either way didn't work.
母語は日本語ですが、英語も喋れます(ry
(12-06-2021, 06:22 AM)ryo Wrote: So if I'm not mistaken, red in pin 6, blue in 10, USB in PC, power the board on, screen command, and then black in 8?
Blue in pin 8, black in pin 10.
Make sure that in the screen command, the baud rate is set to 1500000. Personally, I just use picocom: picocom -b 1500000 /dev/ttyUSB0
Also make sure you're using the right serial port, a USB adapter will usually show up as /dev/ttyUSB0
Oh, also ensure the BAT ON-OFF jumper is in place. It's near the eMMC connector. Some early boards were shipped out without it, in that case you can take a jumper wire (e.g. an unused one from your uart adapter) and use it to connect across the two pins.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
Nice, this seems to have worked!
Thank you!
