Bleachbit on Mobian
Bleachbit : from the Mobian onboard software store installs both user and root in just one install.
  However only the user part part will open and work.?
 Is there an easy work around,  or just wait for the developers to get it working ?
Sent from my PMOS phone, August 22 Mobian/Bookworm Nightly on sd card, PureTalk cell/Data
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I wonder if Bleachbit can be used safely with Mobians f2fs file system ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Well...
I see Mobian has moved from f2fs to ext4...
I do wonder if they will return to the f2fs later, or what..?
Will Bleachbit as 'root' eventually work on Mobian ? ( as 'user' is only a part of the app. that currently works)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(01-06-2022, 08:58 PM)bcnaz Wrote: Well...
With the mobian installer you can choose between f2fs and ext4..
(08-23-2021, 05:49 AM)bcnaz Wrote: Bleachbit : from the Mobian onboard software store installs both user and root in just one install.
Problem is bigger than bleachbit. Many GUI software do not run with root privileges.   In the past gksudo was available to run GUI software as root. Example https://forum.pine64.org/showthread.php?tid=14469 Who has solution?
  Mobian repository status henrythemouse 16 8,744 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 2,002 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 131 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,994 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,819 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,893 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,898 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 630 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,017 06-19-2023, 03:02 PM
Last Post: vusra
