Flashed SPI, able to ping RP64 but not boot from sdcard/usb
Hi
I am flashed the SPI with sigmaris's SPI, and I was unable to boot. So I used the erase image, and it still wouldn't boot. I'm expected my uart today, so I can view whats' going on.
However, I was wondering why it was letting me ping but not ssh. I have imaged a sata ssd with TwisterOS, and also on an sdcard, and neither boots. I think the SPI was flashed correctly (i'm probably wrong) so I am unsure why nothing is booting.
Earlier I was unable to ping at all, until I went through flashing again. So I probably skipped a step I imagine and now I've maybe bricked the rp64?
Thanks for any guidance
Fortunately I have a 2nd rp64, so I am hoping I waiting on this before I go through the hell of it again with the 2nd one
(08-10-2021, 08:47 AM)korefuji Wrote: Hi
EDIT: So I made an image from Armbian, and it boots from SDCard, but at the armbian logo it is perpetually loading.  So some progress, but not sure how to move from there
Hi korefuji and welcome,
  normally it is always possible to erase the spi flash or at least disable it. Fortunately I always succeeded to erase it when needed. If you are able to ping, this means that the device has booted successfully (self evident !) - but in case ... check that you ping the appropriate machine. The problem with ssh may come from :
- a distribution without ssh daemon (rare)
- a firewall of the client from which exec ssh that do not authorize the ssh
You may try to erase again the spi.
You need to flash the u-boot into the spi for sata to boot.
Armbian always worked for me (emmc / sd / nvme / netboot).
Best luck.
  enble boot after power loss/restore dkebler 18 9,424 12-04-2023, 12:14 PM
Last Post: ok38
Photo Max Resolution Supported by RP64? hoarfrosty 3 920 10-24-2023, 09:58 AM
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 119,459 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 666 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,252 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,317 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,548 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,187 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,150 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,797 07-02-2022, 09:24 AM
Last Post: dkebler
