Convergance Dock HDMI resolution:
I have a PinePhone convergence device and dock and when I plug in, the keyboard and mouse work fine but I get no output on the HDMI display.  Is there a maximum (or minimum) resolution that must be supported?  I'm plugging in a Dell Ultrasharp 27 (U2720Q) monitor (specs) which is a 4k panel.
Thanks!
first you have to flash the working firmware in the ANX7688 chip
https://xnux.eu/devices/feature/anx7688.html
https://xff.cz/git/linux-firmware/plain/anx7688-fw.bin
you copy the file with sudo into "/lib/firmware" and you flash it as root giving su with password root and then the echo command
`sudo cp anx7688-fw.bin /lib/firmware`
`su`
`echo 1 > /sys/class/typec/port0/device/flash_eeprom`
after echoing the value "1" into the file "/sys/class/typec/port0/device/flash_eeprom" the flash operation starts and after some seconds the operation is complete and you get back the terminal
giving `dmesg` you will get all the kernel messages of the operation at the end of the output in the following form
[timestamp] anx7688 1-0028: eeprom wr [2+16 bytes in hexadecimal format]
Thanks for the reply!
I have flashed the firmware successfully from looking at the dmesg output.  I've rebooted the device and yet I still cannot get output on the monitor I have plugged into the HDMI port.
Any further steps I need to do in the UI on the phone perhaps to enable the external monitor?
Thanks!
I just tested it too and it doesn't work. I searched and as I can understand you have to detect and activate the monitor, in classic X it would be done with xrandr, on Pinephone it depends on the distro and if it is using wayland as with Plasma, if I solve it I will comment here.
(08-10-2021, 07:05 AM)bceverly Wrote: Thanks for the reply!
Thanks!
Did you get this to work?
Enough is plenty. Good enough will do.
  PinePhone Dock with laptop? Mikey1977Y2J 2 635 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Why do mouse, keyboard and HDMI not work with 3.th party usb-c adapters? Peter Gamma 3 4,078 03-27-2023, 01:59 AM
Last Post: Peter Gamma
  Pinephone Pro Convergence Dock Ethernet performance with non-pro pinephone Matt2020 10 4,569 03-07-2023, 12:33 PM
Last Post: emsyr
  Gembird USB Typ-C to HDMI has no HDMI output when connected to PinePhone PostmarkedOS Peter Gamma 1 1,368 06-13-2022, 09:53 AM
  The PinePhone USB-C dock of the magician Martijn Braa Peter Gamma 0 928 06-12-2022, 08:24 AM
Question Keyboard Case + Convergence Dock Merc 5 3,276 04-21-2022, 10:24 AM
Last Post: zetabeta
  Convergence dock not charging pinephone mobian tecnocris 8 8,507 09-11-2021, 06:43 PM
Last Post: bcnaz
  Uses for a DoA USB-C dock (disassembly/recycling) kartynnik 3 3,535 07-10-2021, 07:16 PM
Last Post: kartynnik
Heart PinePhone / Pine Tab dock or PineBook hockleyj 5 8,479 12-10-2020, 03:47 AM
Last Post: sbl
  PineTab-style USB-C dock jfrederickson 2 3,700 12-08-2020, 11:05 AM
Last Post: nas
