Phosh Menu and Lockscreen Icons
Can anyone point me towards the documentation on Phosh's lock screen and menu icons?
I like the icons that Manjaro Phosh is using for service indicator, battery, wifi, etc, a bit more than the default I've seen used by Arch and Mobian. I'm trying to get my Arch installation all buttoned up as a daily driver and this is one of the last (I'll be it very minor) things I'm trying to configure Smile
Thanks!
  • PinePhone BraveHeart, needs modem replaced, used for experimenting with new OS's.
  • PinePhone Manjaro Community v1.2b 2G/16Gb Daily Driver
  • Pinebook Pro Arch Linux, Daily Driver
(08-04-2021, 04:43 PM)d0n601 Wrote: Can anyone point me towards the documentation on Phosh's lock screen and menu icons?
Thanks!
The icons are included in the papirus theme, so you would have to install and activate that theme. It's explained here in the Mobian wiki.
sudo pacman -Sy papirus-icon-theme
gsettings set org.gnome.desktop.interface icon-theme 'Papirus'
Thanks!
Yep that definitely did it, fantastic. I had the Papirus-Dark-Maia icon set installed, but I'd gotten it from outside the package repo for some reason, that must have been my issue. These steps were perfect.
Thanks for the Wiki reference too.
  stuck between phosh and plasma aular 0 226 02-27-2024, 05:55 PM
Last Post: aular
  How to find software app, on Arch Phosh? general_lee 5 1,934 10-15-2023, 10:12 PM
  Evolution no longer runs on Arch Phosh. Chief 2 1,388 10-17-2022, 07:22 AM
Last Post: Chief
  Scaling problem Arch Linux Phosh Chief 7 3,175 09-27-2022, 12:31 PM
Last Post: Chief
  How to upgrade Phosh on Pinephone? ibid 1 1,284 08-18-2022, 09:02 PM
Last Post: mikehenson
  repository for arch-phosh oihantto64 8 5,960 06-27-2022, 03:00 AM
Last Post: shulamy
  Best Messaging client for pinephone? (arch-phosh) pineuser0 20 15,954 03-23-2022, 07:13 AM
Last Post: saba
  audio services shut down after short time on arch-phosh pineuser0 3 2,634 01-22-2022, 01:14 PM
Last Post: elagost
  how to make a terminal command run as an icon in arch-phosh pineuser0 3 3,101 12-06-2021, 03:41 PM
Last Post: brb78
  Can't install arch-phosh with dd, only with etcher. pineuser0 5 4,015 11-23-2021, 07:32 PM
Last Post: cabbie001
