Working suspend on Manjaro
Hi, just wanted to let you know that after flashing Tow-Boot to SPI I've got working suspend. Steps are described in updog's response here on Reddit: https://www.reddit.com/r/PINE64official/..._pinebook/
The instructions worked for the first release. I haven't checked out the new one yet since it requires a SD card
Yes, I agree, towboot will do s3 suspend (with right kernel & config)
However, it is NOT as good as BSP uboot, perhaps 50% worse
BSP = 7% / day,,, towboot 11-12% / day
It (towboot) will do a couple things that I never have seen other uboots do
(beside menu display)
(07-28-2021, 12:36 PM)brzegorz Wrote: Hi, just wanted to let you know that after flashing Tow-Boot to SPI I've got working suspend. Steps are described in updog's response here on Reddit: https://www.reddit.com/r/PINE64official/..._pinebook/
Hi, was this on Manjaro (or 5.13 kernel)?  And would it work if running from SD card? Thanks in advance.
Just noting here that I just did some clean install tests with Manjaro KDE and Tow-Boot. With "pinebookpro-linux" kernel (5.7.x) I was getting black screens after wake from suspend, but with the default "mainline" kernel of 5.15.x at the time of writing, it wakes fine from suspend. I have confirmed that "deep-sleep" mode is being activated by checking "dmesg | grep suspend". I did an overnight test and in 9 hours I lost about 18% battery, so about 2% per hour which isn't great but is much better than it being "dead" the next morning if I don't plug it in overnight. Since no problems with sound, black screen, etc. I am going to stay with this mainline kernel and Tow-Boot for the time being. I couldn't get deep-sleep working in Armbian FWIW even with Tow-Boot. Since Armbian has dropped support I will be staying with Manjaro for now.
  Manjaro Sway Theme Broken Eighty8 1 264 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,724 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 309 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,089 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,169 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 390 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 863 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  USB 3 port not working with Armbian zaius 3 824 11-13-2023, 01:54 PM
Last Post: zaius
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,999 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,949 08-21-2023, 09:08 PM
