What's your experience with the updated touchpad firmware?
Feels nearly perfect
65.93%
60
Better, but still not issue-free
26.37%
24
No real improvements
3.30%
3
Firmware update failed
4.40%
4
91 vote(s)
Finally... The touchpad works great!
(02-14-2022, 02:41 PM)UltraBlack_ Wrote: Hm, for me the updater fails at step 2 even though it passed step 1:
Verify mismatch: type=f2, pass=e2, recieved=d2
How would I go about solving this?
You should shutdown(not reboot) after flashing step 1
Oh welp that fixed it. I expected rebooting to function as power cycling as well. Thank You!
Much better. But still quite far behind consumer laptops.
(05-31-2022, 09:17 AM)vatin Wrote: Much better. But still quite far behind consumer laptops.
Yeah, they have Trackpoint  Tongue
:wq
[ SRA accepts you ]
Just to add to the thread for no other reason than to cheer.
New touchpad software works great Smile This improvement actually makes it usable.
Having to use Manjaru for a few days, I can understand why some people think there's still room for improvement. Default Manjaru is very sluggish compared to the NetBSD installation I've been using. But it did take me a while to get the user settings to that point. So I expect with careful tuning of the touchpad parameters in Plasma on Manjaru, most everyone will much appreciate the way the touchpad works since the firmware update.
:wq
[ SRA accepts you ]
firmware
just a new guy here, but simple commands seemed to fix the lag in my cursor for my pinebook pro running fedora. shakey on some basic concepts, but didnt want to risk bricking my tracpad and/or keyboard..following given flashing instructions to a tee, i booted my manjaro from sd for flashing (as im not totally comfortable with fedora or even cli's yet and manjaro steps were completely listed). Super easy, very happy, Thank you!!
Could it be, that I need to reinstall the firmware update after a reinstallation of Manjaro?
I have the feeling that my touchpad has gotten worse again. But I don't want to sacrifice my potentially limited amount of flashes without a reason. Smile
Hello,  I  have the  SH61F83  chip.  did you ever get verification that it's the same IC and can do many  changes of  OS  distro's to it?
This would be good to know
   thanks
(08-15-2021, 05:29 PM)bootsup Wrote: I installed the Manjaro package on my early 2021 PBP.
Step 1 and Step 2 were successful. However:
$ sudo pbp-fwupdate flash-kb firmware/default_ansi.hex
Please note that updating the firmware carries a small risk
of permanently disabling the trackpad and keyboard, effectively
bricking them.  Proceed at your own risk.
Press Ctrl+C within the next five seconds to cancel... 5 4 3 2 1
Segmentation fault
I have the same issue as this.  Has anyone found a solution yet?
  PBP green LED works but blank display. frerebo 1 808 02-22-2023, 03:11 AM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,145 09-14-2022, 03:56 AM
Last Post: Carl
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 3,118 02-05-2021, 09:10 AM
Last Post: BlueJayLinux
  Sticker on touchpad fbkr 3 5,312 11-10-2020, 10:10 PM
Last Post: pFalken
  Touchpad self generates events jpalus 0 1,981 10-18-2020, 11:38 AM
Last Post: jpalus
  Do I need the touchpad update? Paulie420 3 5,435 09-22-2020, 06:40 PM
Last Post: Paulie420
  touchpad tanzim8145 2 4,828 06-06-2020, 02:56 AM
Last Post: lot378
Bug open wifi works and secure wifi does not j3bel 2 4,080 06-02-2020, 01:55 PM
Last Post: j3bel
  Right Click touchpad sensitivity tomfowler 4 6,195 05-31-2020, 12:32 PM
Last Post: gwalker
  lol touchpad causes mouse to move all over the place when using in a car james64 0 2,121 02-05-2020, 08:16 AM
Last Post: james64
