Thunderbird - anyone using it on Mobian?
Is anyone using Thunderbird on Mobian?
I'd like to copy across my profile from a PC and wondering whether it might work.
Also wondering where to put the profile under Linux.
Tnx
Thunderbird keeps everything in a hidden directory called .thunderbird in your home directory, that is "~/.thunderbird", copy it in your phone's home directory and it should work
Great. Thanks.
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,931 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 17,653 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,233 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No sound after Mobian upgrade arbocenc 1 759 11-28-2022, 11:02 AM
Last Post: arbocenc
Exclamation No wIfI after Mobian update crakabeats 3 2,108 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  pinephone-support package not upgradable on Mobian fhireman 4 2,347 09-24-2022, 08:01 AM
Last Post: dante404
  PinePhone running Mobian - Malware extraction? names_fold 1 1,625 01-24-2022, 12:00 PM
  Mobian updates for phosh steves 2 2,079 01-17-2022, 02:18 AM
Last Post: bcnaz
  Assists for running Mobian my PinePhone gilwood 0 1,595 01-01-2022, 04:38 PM
Last Post: gilwood
  ? vpn or tor for mobian rvh 9 7,205 12-02-2021, 05:58 PM
Last Post: b7l3wui26r
