Second screen with usb type-C
I got a usb-c to vga adapter, but when I use it to connect a screen to the rockpro64 it does not work.
The adapter does work if I connect it to a laptop, so the issue here is about the rockpro64.
Does anyone know how to make the adapter work for the rockpro64?
I do not see any output in dmesg when I connect the adapter to the usb-c port, but if I connect other devices to it it works properly (I have a usb-c to ethernet adapter that works fine). So the problem seems to be only with the screen adapter.
Thanks!
  screen reader Orca on Ubuntu 18.04 Bionic LXDE Desktop 32bit bluciano 0 1,979 05-07-2020, 03:31 AM
Last Post: bluciano
  USB Type-C Display cable support (for 2 in 1: Video + Power) Paprika88 0 2,392 02-12-2020, 06:47 AM
Last Post: Paprika88
  7″ LCD Pine64 touch screen + RockPro64 + Linux Impact 0 3,008 02-07-2019, 04:03 AM
Last Post: Impact
  rock64pro - using gigabit ethernet dongle on usb type C dkebler 2 3,262 09-07-2018, 12:41 AM
Last Post: steamiestoyster
  Clarification of type-c superspeed device mode cpwrunner 4 6,290 07-03-2018, 11:44 AM
Last Post: cpwrunner
