Hello my frend. How to fix my boot problem?
Tongue
I am a new user in Linux and a new owner of a pinebook pro from Russia Smile . How to fix booting after incorrect installation of Manjaro?[Image: 8352IMG_0859_800.jpg][Image: i.gif][Image: IMG_0858_800.jpg][Image: i.gif]
i installed uboot-pinebookpro-bsp visual artifacts disappeared, in which direction to look, prompt to fix errors:
[ 1.830285] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22
[ 2.509700] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 2.936889] rockchip-dp ff970000.edp: no DP phy configured
[ 3.059417] usb 2-1.2: device not accepting address 3, error -71
until the software problems are solved, I decided to decorate the appearance Smile [Image: IMG_0861_800.jpg][Image: i.gif], [Image: IMG_0862_800.jpg][Image: i.gif], [Image: 41472IMG_0863_800.jpg][Image: i.gif]
Probably your easiest route at this point is just to reinstall Manjaro (or your choice of other operating system) anew.
You can write a bootable image to micro-sd card and boot that, and then install to eMMC. Or, you can remove the eMMC and flash it in another computer with an adaptor.
:wq
[ SRA accepts you ]
(07-03-2021, 08:16 PM)KC9UDX Wrote: Probably your easiest route at this point is just to reinstall Manjaro (or your choice of other operating system) anew.
I have already reinstalled many times from micro sd to emms. all I have achieved is the green artifacts on the screen have disappeared and the errors remain. there are no errors when booting from a micro SD image mrfixit2001.
Well, you probably don't want to hear my opinions about Manjaro. Smile I do have it running on my wife's PBP, but I only update it every six months and so far have been lucky, I guess. My PBP runs NetBSD, and (now very, very rarely) the mrfixit2001 Debian.
:wq
[ SRA accepts you ]
In that case you can try to install the U-boot from mrfixit2001.
Perhaps this thread can help: https://forum.pine64.org/showthread.php?tid=10031
  uboot wont boot to SD card after upgrade jbradley419 7 751 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 273 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,163 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 653 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 562 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,141 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,810 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 787 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,907 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,393 05-20-2023, 01:02 AM
Last Post: jackwilson
