4K@30 video output does not work properly on Pinebook Pro
Bug
I have Pinebook Pro connected to LG 27UD88-W monitor via USB-C to DisplayPort cable. I'm running Manjaro ARM 21.06 (Linux kernel 5.12) with Sway WM. The problem is that I can't run 4K @ 30Hz properly (right 1/3 of the screen is distorted). FullHD (1920 x 1080) and WQHD (2560 x 1440) works just fine. I have also tested X11 based Linux distros and the issue is the same. Anybody had luck to run 4K @ 30Hz video output on the external monitor?
This is the similiar thread, but it is closed.
I will be more than happy to provide more details if necessary.
$ dmesg | grep cdn-dp
[    5.395293] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[    5.395302] cdn-dp fec00000.dp: Falling back to sysfs fallback for: rockchip/dptx.bin
[   69.610270] cdn-dp fec00000.dp: [drm:cdn_dp_request_firmware [rockchipdrm]] *ERROR* failed to request firmware: -11
[  101.919603] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Connected, not enabled. Enabling cdn
[  549.569829] cdn-dp fec00000.dp: [drm:cdn_dp_check_sink_connection [rockchipdrm]] *ERROR* Get sink capability timed out
[  549.570998] cdn-dp fec00000.dp: [drm:cdn_dp_encoder_enable [rockchipdrm]] *ERROR* Failed to enable encoder -19
  Debian on Pinebook Pro u974615 7 852 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,459 02-22-2024, 04:02 PM
  Streaming video sites tessa 1 1,026 01-19-2024, 03:47 AM
Last Post: similarwham
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,082 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,164 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,073 12-08-2023, 11:25 PM
  No Video Out on PBP on all major distros misha64 9 2,728 11-28-2023, 01:41 PM
Last Post: zaius
  Boot Order in Pinebook Pro food 8 1,177 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,164 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,454 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
