Problems with Pinephone camera ov5640
Hello, I try to make the ov5640 camera working...
Problem: no autofocus function because ov5640_af.bin seems not to work with the ov5640 camera modul installed.
I ordered another ov5640 camera modul from pinephone and replaced it with the one installed. Same result: no function.
So I think it is not a problem with hardware instead of software.
My question: Is there a way to get a ov5640_af.bin from the vendor of the 0v5640 camera modul?
Is it possible to get the source of ov5640_af.bin?
Is it possible to replace the camera modul with ov5647 or a successor of ov5640?
Thank you in advance
greetings
  PinePhone - boot from microSD laserpyramid 7 571 9 hours ago
Last Post: aular
  pinephone virtual keyboard aular 4 349 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 232 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,006 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,794 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 605 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,359 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 495 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,685 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,953 12-04-2023, 02:14 AM
Last Post: Peter Gamma
