Pinebook Pro not powering on when eMMC hardware switch is off
Hi All,
I'm currently having an issue booting my Pinebook Pro.
I tried to flash an image of TwisterOS on the eMMC but I don't believe that was done correctly.
I searched the forum and find that is possible to perform a reset option by forcing the Pine to baypass the eMMC deactivating it with the hardware switch on the SoC board.
When I'm doing that the Pinebook won't power on at all, is that anything wrong there?
If I remove the eMMC from the slot it's not working either.
Anybody able to help?
Thanks in advance!
If there is no uboot, or a bad uboot, the pbp will appear dead
If there is a bad uboot, it may 'remember' and also not be bootable (later)
For example, put a a64 sd card in, you will think you have bricked it
It will appear dead, recover by a reset, long presses or remove back (and press reset)
So try another image or redo burn or another card
The power light is driven entirely by software. So it will not turn on at all until the software, usually U-Boot turns it on. Therefore if it doesn't turn on, you either have a U-Boot that doesn't turn it on (unheard of), or U-Boot isn't running.
  Pinebook Pro Initial Impressions kunger 443 587,641 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,281 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 392 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 285 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 218 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 661 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 730 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,592 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,220 12-15-2023, 02:11 PM
