Is my VoLTE working?
Hi, I followed all the instructions I could find to get VoLTE working. My carrier "Consumer Cellular" uses AT&T network which is soon totally disabling 3G so I must get VoLTE working. However I'm not sure if it is working. I need help understanding it.
I have Manjaro CE with Phosh.
I reached the carrier support and they succesfuly detected the modem model and enabled something on their end to allow VoLTE.
I followed the VoLTE steps on the main PinePhone wiki page.
AT+QCFG="ims"
+QCFG: "ims",1,1
OK
The 4G indicator shows in the UI. To test, I called my wife.
#Start call to my wife:
[root@manjaro-arm ~]# echo 'AT+CLCC' | atinout - /dev/EG25.AT -
+CLCC: 2,1,0,1,0,"",128
+CLCC: 1,1,0,1,0,"",128
+CLCC: 3,0,0,0,0,"4436179824",129,"Andrea"
+CLCC: 4,1,0,1,0,"",128
OK
#Hang up:
OK
[root@manjaro-arm ~]# echo 'AT+QNWINFO' | atinout - /dev/EG25.AT -
+QNWINFO: "FDD LTE","310410","LTE BAND 2",700
OK
Elsewhere I have read that the fourth value of AT+CLCC tells you whether the voice is carried by VoLTE. The Quectel AT command reference says ony this about it:
<mode>Bearer/tele service
0: Voice
1: Data
2: FAX
However the line with my wife's phone number has a 0 in that position. Still I wonder, with all the other symptoms lining up??
This example would suggest so https://forum.pine64.org/showthread.php?...7#pid86137
You're also registered on IMS.
If your phone stays on 4G then yes, it's VoLTE for sure, if it drops to 3G (or 2G) for the call, then no.
You can also check whether or not you're on 4G during the call (rather than after) using
mmcli -m any --command='AT+QNWINFO'
You might add this to the other thread if it's confirmed.
  4G VoLTE calls confirmed working with carrier x dcinoz 15 11,827 03-09-2024, 11:38 PM
Last Post: dcinoz
  pinephone with lte-m chip and volte zetabeta 0 662 10-02-2023, 05:42 AM
Last Post: zetabeta
  MMS sending stopped working amindfv 2 1,238 01-16-2023, 09:44 PM
Last Post: treebeard
  Instructions to get pinephone working on USA carrier omarcomputing 1 1,364 10-08-2022, 04:45 PM
  JumpDrive isn't working phytocube 2 1,781 06-05-2022, 03:22 PM
Last Post: phytocube
  likely bug, volte does not work when operator side data blockage is activated zetabeta 1 1,273 05-21-2022, 03:03 PM
Last Post: zetabeta
  voLTE Bell optimus 1 1,785 02-12-2022, 05:40 PM
Last Post: optimus
  SIM card slot not working dekrets 2 2,203 02-12-2022, 11:09 AM
Last Post: dekrets
  Can't get autofocus working duncan_bayne 4 2,930 01-22-2022, 09:17 PM
Last Post: duncan_bayne
  PinePhone Beta 3GB modem not working hannescam 15 9,104 01-19-2022, 02:08 AM
Last Post: bcnaz
