2021 Jun 23 Updates breaks chatty [solved]
I did an update tonight (2021 Jun 23) and the chatty app stopped working.
$chatty
$chatty: symbol lookup error: chatty: undefined symbol: _ZN4i18n12phonenumbers11PhoneNumberC1EPN6google8protobuf5ArenaE
I had to downgrade these packages to make it work again.
boost-libs-1.76.0-1 to boost-libs-1.75.0-3
evolution-data-server-3.40.2-2 to evolution-data-server-3.40.0-2
libphonenumber-8.12.25-1 to libphonenumber-8.12.21
protobuf-3.17.3-1 to protobuf-3.15.8-1-
I am not sure where to report this issue, but this post did help me.
EDIT:
As of 2021 Jun 24 this is no longer an issue with the update of chatty to chatty 0.3.1-2
Same thing happened to me. Will try to fix. Thanks!
Not sure if this is related, but I had to (re)install modemmanager for chatty + SMS
  Chatty not receiving encrypted xmpp messages on suspend mode user641 0 724 11-17-2022, 05:16 AM
Last Post: user641
  Chatty and OMEMO user641 1 1,131 09-27-2022, 12:47 PM
Last Post: user641
  no audio ring on non chatty calls nemsys 0 752 08-14-2022, 03:23 PM
Last Post: nemsys
  2022 01 28 Updates Break Chatty mikehenson 5 3,266 02-12-2022, 09:31 PM
Last Post: Danct12
  Howto enable MMS support in Chatty on Phosh? (PinePhone) ramona.fulton 2 2,761 11-18-2021, 02:58 PM
Last Post: Danct12
  Discover does not show any updates firefox-58 0 1,270 07-16-2021, 12:21 PM
Last Post: firefox-58
