How to install a Whatsapp client on Pinephone w/ Manjaro?
Question
Fellow Pinphoners!
I'm an "enthusiast" grade user and need some advice. I'm running the latest Beta edition of Manjaro ARM with Phosh and I need to install a Whatsapp client on it. Has anyone here done this successfully? Any pointers or better would be greatly appreciated. TIA.
Since writing I found this, but the commands aren't suitable for Arch Linux. Can someone please help me with the appropriate commands for installation, if it's possible? Many thanks.
https://itsfoss.com/whatsapp-linux-desktop/
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
My best advise would be to not use WhatsApp and anything Fakebook altogether for all sorts of reasons, but your device; your choice.
You'll only be able to run something compiled for ARM (or open source software that can be compiled to ARM).
The app seems to be open source, but as far as I experienced, Electron can be pretty anal on Phosh and PlaMo at the moment.
Another way around is to have a burner Android phone for just that, assuming you never need to chat outside of your home.
母語は日本語ですが、英語も喋れます(ry
  pinephone virtual keyboard aular 4 297 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 198 04-02-2024, 11:50 AM
  install iso from sd card to emmc aular 2 290 03-11-2024, 10:24 PM
  PinePhone - boot from microSD laserpyramid 5 469 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 107,922 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,713 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 571 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,253 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 471 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,630 12-22-2023, 03:44 PM
