07-03-2021, 10:23 AM
Dependency resolution failed
07-04-2021, 06:58 AM
Thank you, worked perfectly! ?
12-14-2021, 10:12 AM
(06-19-2021, 10:39 PM)nelstomlinson Wrote:(06-19-2021, 06:24 PM)RRman Wrote:It's downloading stuff now, looks like that is working. Libcanberra is getting replaced by /extra/libcanberra, and there were a couple of others like that. I said Y to all.(06-19-2021, 01:29 PM)nelstomlinson Wrote: Tried to update my beta edition phone this morning, using Discover.Use the terminal and type: Hi all, PP Beta Manjaro/Plasma, new Linux user. Unable to update the system, 524 updates, many months behind the OS updates published. It is seeing new ones as they are added. 1. When I try with Discover, I get the dependency issue involving libcanberra identified above. Previous advice I received in the main Pine64 chat was to move the libcanberra file to a different folder; I don't know what the file would be called but have searched the folders for any related files and haven't found it/them yet. Also, in Discover there is a "remove" button for libcanberra under "already installed" but it did not work (seems an unimportant file(s) but I will not repeat this risk as a new user). 2. When I try with Terminal, either pacman -Syu or pacman -Syyu, I am prompted for 6 y/n's (do you want to replace) including for libcanberra, I enter "y" for all, it ends with no updates performed and lists 21 errors for 21 files that are "already in the system." It does not matter if I use ethernet or WiFi. Can anyone help? Reinstalling OS is (unsurprisingly) new to me, but I will do it if needed. Thanks! |
How to find and remove junk files from failed updates? | danimations | 4 | 3,360 |
10-24-2021, 11:25 PM Last Post: danimations |
External Display Resolution Change | TheBlindEarthican | 3 | 3,852 |
12-08-2020, 05:21 AM Last Post: hobbitus |
