Pinebook pro nearly unusable after using manjaro-arm-installer
Good afternoon everyone, about a month ago I tried using the manjaro-arm-installer script to flash the emmc. This completely bricked my device, no booting from emmc or sd card, not even the green LED power light would come on. Finally got around to opening the thing up and hitting the RESET button. This got booting from the sd card working again, but the performance is absolute garbage. I can get to the manjaro KDE desktop but it will freeze if I try to do anything useful. I'm at my wit's end with this thing, any guidance you can offer would be greatly appreciated, Thank You!
(06-18-2021, 03:34 PM)TheCounselor Wrote: Good afternoon everyone, about a month ago I tried using the manjaro-arm-installer script to flash the emmc. This completely bricked my device, no booting from emmc or sd card, not even the green LED power light would come on. Finally got around to opening the thing up and hitting the RESET button. This got booting from the sd card working again, but the performance is absolute garbage. I can get to the manjaro KDE desktop but it will freeze if I try to do anything useful. I'm at my wit's end with this thing, any guidance you can offer would be greatly appreciated, Thank You!
I find KDE to be heavy on an SD card (arguably, on the eMMc as well), so I prefer Xfce, gnome, i3 or sway, any of these are much better in my experience.
As for not being able to run manjaro from the eMMc, only the SD, installing bsp uboot could do the trick, I have to use it with Manjaro and Arch otherwise it won't boot.
Give Armbian a try.
Cheers,
TRS-80
Protocols, not Platforms
  Debian on Pinebook Pro u974615 8 449 03-22-2024, 03:57 PM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 171 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,126 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,609 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 219 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,921 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,981 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 86,673 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 295 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 994 11-23-2023, 07:37 AM
