My PinePhone shuts down when the screen turns off
My PinePhone works normally, but when the screen turns off by any reason (inactivity or because I pressed he button on the side), the phone shuts-down immediately. To explain better, as the screen turns-off, the phone seems normal, but when I press the button again, nothing happens for a few seconds, and then the LED turns red, then white and then green. The boot loading screen then appears. I can repeat this indefinitely.
My version:
PinePhone UBports Edition
Ubuntu 16.04
UBports Image Part
20210610-24867
Device Image Part
20210613-8159
What have I done:
- Reset Launcher
- Erase & Reset All
- Updated the OS and all apps.
- "Reinstall all apps"
Details:
I'm not using a SIM card
I would be glad if any one has any clue on how to fix this
  pinephone virtual keyboard aular 4 299 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 199 04-02-2024, 11:50 AM
  PinePhone - boot from microSD laserpyramid 5 470 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 107,974 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,716 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 574 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,257 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 475 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,635 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,852 12-04-2023, 02:14 AM
Last Post: Peter Gamma
