[major issue] how to stop it from booting when charging?
I bought a pinebook recently to play around and have a cheap laptop with me during travels and I have one major issue with it.
When I plug it in to charge it it will boot immediately. When I turn it off it stops charging also. This is very problematic as I planned on charging it using solar panels on a trip.
Is there a way to change this in the BIOS or something like that? I'm leaving in less than two weeks :/
Thanks!
(06-08-2021, 05:55 AM)eFqLLnGo Wrote: Hi,
Thanks!
The Pinebook will boot up from power off mode when plug in power.
I have the issue with booting when you plug in the charging cable too. But when charging while the pinebook running and then I shutdown the system, the pinebook keeps charging while it is off. So I use it as kind of a workaround.
  Not booting anymore from SD oloturia 0 486 09-29-2023, 10:18 AM
Last Post: oloturia
  Booting with TOC0 u-boot -- should it work? dreadbit 0 763 11-24-2022, 10:19 AM
Last Post: dreadbit
  Pinebook Pro availability, booting from NVMe nooryani84 8 12,106 09-16-2019, 11:07 AM
  No HDMI output, hardware or software issue? TAO.vision 9 13,910 05-15-2018, 12:36 AM
Last Post: fbn
  Pinebook not booting for the 1st time Tionicer 7 7,322 08-31-2017, 08:30 AM
Last Post: Manuel M.A.
  Pinebook Solar charging Soul_Hacker 2 3,787 08-24-2017, 04:02 AM
Last Post: Soul_Hacker
Exclamation Flashing New OS Images to eMMC / Booting from SD Luke 0 9,760 06-30-2017, 12:26 PM
Last Post: Luke
