PBP won't boot
Hi!
Yesterday, I rebooted my PBP and it did not boot again. The green power led is not on.
I have 2 power supplies, and I see that the red light is not lit with the one I used yesterday. I have created a support ticket for this defective power supply.
So it could be I drained the battery to 0%.
I plugged the PBP all the night to recharge the battery.
I tried to unplug the battery and use the bypass cable, long press on the power button, press the reset button, but no success.
I tried to boot a SD card but no success too.
Before this state, the OS on the eMMC and on the SDCard were working fine (Gentoo like all my PC and other ARM servers).
I don't have the official debug cable, but I can make one with a USB FTDI cable and a hacked jack cable.  Or do you have any reference I can use instead? or wait until it's available on the Pine Store?
I did NOT flash the SPI nor U-BOOT, they are working and I don't want to brick the boot process. I only did a repartition on the existing Manjaro, keeping the start offset of the first partition.
What operation can I do to unbrick it?
Thank you very much!
Kind regards,
Xavier
Kind regards,
Xavier Miller.
luckily the pbp is unbrickable, so you can recover it. If you drained your battery down to 0, overnight likely isn't a long enough recharge. i've always had to let mine recharge (from 0) for 18-24h.
Hi!
you give me hope :-)
Do I need to wait until the battery is full or can I try it half-charged?
Do I need to find/build a debug cable?
Do you have any reference that is OK ? Many of those I see are reverted (Tx on tip), or at 5V...
This Delock cable ?
https://www.reichelt.com/de/en/cable-usb...63097.html
Kind regards,
Xavier Miller.
I found one at amazon fr : https://www.amazon.fr/gp/product/B08VS46V91/
Let's hope it's OK
This cable will permit me to fiddle with U-BOOT or SPI
Kind regards,
Xavier Miller.
Hi!
I got a working debug cable and I can access to the boot process.
I have a boot loop. Do I need to go into recovery mode and reset U-BOOT ?
Usb re Boot. 18097204
SoftReset
DDR Version 1.20 20190314
In
soft reset
SRX
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x82
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 315
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=59640MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 70838
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
LoadTrust Addr:0x4400
LoadTrust Addr:0x4800
LoadTrust Addr:0x4c00
LoadTrust Addr:0x5000
LoadTrust Addr:0x5400
LoadTrust Addr:0x5800
LoadTrust Addr:0x5c00
Addr:0x4000 No find trust.img!
LoadTrustBL error:-3
powerOn 97782
Usb re Boot. 6097777
In
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
OUT
CPUId = 0x0
ChipType = 0x10, 249
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=59640MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 70600
SecureMode = 0
recovery gpt...
recovery gpt fail!
powerOn 96251
Usb re Boot. 6096248
Usb re Boot. 12096251
Usb re Boot. 18096256
SoftReset
Kind regards,
Xavier Miller.
SOLVED: I got access to maskrom mode, empty the SPI flash, then flash U-BOOT from Manjaro to SPI and the system is back!
Kind regards,
Xavier Miller.
  uboot wont boot to SD card after upgrade jbradley419 7 802 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 286 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,210 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 686 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 584 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,171 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,863 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 795 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,924 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,426 05-20-2023, 01:02 AM
Last Post: jackwilson
