Can't boot from eMMC or SD card...
I broke my Arch system on my Pinephone with an incomplete update. Now I can't boot from eMMC, the loading screen roll forever.
I tried to flash Jumpdrive to SSD card. But my Pinephone won't boot to SSD card, it start Arch from eMMC anyway.
There is a solution to repair my Pinephone ? If i can chroot or something it could be nice...
Thank you !
I believe you need console cable (https://pine64.com/product/pinebook-pine...46c16e2e66) and from uboot prompt you can do recovery. I've ended up in similar situation with pbp and only tweaking with uboot got me saved.
Issue for me was that partition on emmc was corrupted, and uboot boots kernel from microsd first partition - but based on partition naming, uboot assumed that emmc root file system partition was ok (which was not). And boot ended up stuck for this reason.
So get cable and force uboot to use microsd based boot partition for kernel and rootfs.
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 185 04-02-2024, 11:50 AM
  install iso from sd card to emmc aular 2 274 03-11-2024, 10:24 PM
  PinePhone - boot from microSD laserpyramid 5 450 03-06-2024, 06:37 PM
Last Post: aular
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 891 01-09-2024, 07:02 PM
Last Post: britelite
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,158 08-28-2023, 11:38 AM
Last Post: fxc
  Pinephone won't boot. spha 12 2,686 08-20-2023, 02:44 AM
Last Post: spha
  SD Card has wrong capacity AndyM 11 2,287 06-11-2023, 12:30 AM
Last Post: AndyM
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,434 05-10-2023, 03:31 AM
Last Post: fxc
  Jumpdrive broken? eMMc broken Uturn 5 1,714 04-21-2023, 12:37 AM
Last Post: Uturn
  trouble flashing eMMC TylerBlackberry 3 1,196 04-13-2023, 05:55 AM
