Talos on ROCK64
I'm trying to get Talos working on my oldish Rock64 board. The PCB says, "ROCK64 V2.0 2017." The Talos devs have a distribution for ROCK64, and one of their engineers says he's got it running on a ROCK64 board. His says "V3 2019." His works, mine doesn't. But mine works just fine when it's running Ubuntu.
According to my packet sniffer, my ROCK64 never sends a DHCPDISCOVER packet. But it seems like the ROCK64 thinks it sent one, and it's waiting for a reply that never comes.
Does it seem likely that there's a hardware or firmware difference between V2 and V3 that's preventing the Talos Linux kernel from talking to the ethernet? Or does it seem more likely that I've messed up my network somehow?
I'm attaching two excerpts from the console log running Talos.
.txt   dmesg1.txt (Size: 1.68 KB / Downloads: 231)
.txt   dmesg2.txt (Size: 1.03 KB / Downloads: 240)
Have you double checked your OS media and power?  These should be the first 2 things you look at when troubleshooting pretty much any issue, before even going further into some other things you speculate here.  If nothing else than to eliminate them as possibilities.
Following link is for Armbian, but most of it is generally applicable to any SBC.
https://docs.armbian.com/User-Guide_Basi...eshooting/
Don't believe me?  These are so common that we have an entire sub-forum dedicated to them:  https://forum.armbian.com/forum/31-sd-ca...su-issues/  And also why this info is mentioned first, right at the top of troubleshooting section (linked above).
Cheers,
TRS-80
Protocols, not Platforms
(06-03-2021, 08:58 PM)TRS-80 Wrote: Have you double checked your OS media and power?
Thanks for the links, TRS-80. I have 5 identical boards all supplied by PoE splitters from the pine64 store. They're connected via short CAT5e cables to a switch that claims it's delivering 17W out of 150W that it's capable of. So I think I'm good on the power supply.
The ROCK64 is powering a small USB hard drive also. I tried unplugging that and repeating the boot, and I got the same results.
I've tried flashing the SD cards twice: Once from a Mac using dd, and once from Windows using rufus. Still, I just tried again using balena etcher, and I get the same result.
Do you think I've been thorough enough checking the power and media?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 150 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,356 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 334 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 613 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 608 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,361 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,418 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 591 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 650 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,325 12-07-2022, 08:22 PM
Last Post: luminosity7
