I just got to find phone in my sd card won't read
I just got my Pine phone with 3 gigs 32 gig internal I try putting an SD card in it and it won't recognize it and he will know what's going on?
If you boot from EMMC (internal memory) and you want to use your SD as data storage you need to mount it from terminal.
There's no automount in phosh or plasma-mobile
Assuming you have only 1 partition on your SD, try this:
cd ~
mkdir ~/SDCard
sudo mount /dev/mmcblk1p1 ~/SDCard
if everything is fine you can edit /etc/fstab to permanently mount it at boot
(06-02-2021, 10:12 PM)nightranger73 Wrote: There's no automount in phosh or plasma-mobile
In Plasma Mobile you can mount a SD card using the installed file manager Index.
Just touch the button bottom left just above the "three horizontal line button", and touch the SD card in the opened list. It will be mounted and you can access it already using the same procedure.
(06-02-2021, 10:12 PM)nightranger73 Wrote: If you boot from EMMC (internal memory) and you want to use your SD as data storage you need to mount it from terminal.
cd ~
mkdir ~/SDCard
its like the cd card isnt fitting right
says special device does bot exist. do i need to format it?
Hey…Looks like your SD card is corrupted or damaged due to which it is unreadable. So, in order to fix an unreadable SD card, you have to simply follow the tips mentioned in the below-given post:
https://www.rescuedigitalmedia.com/how-t...windowsmac
  Looking for the "non-phone" OS wakyct 7 945 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 4,751 03-11-2024, 10:42 PM
Last Post: Emelia525
  install iso from sd card to emmc aular 2 179 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 794 01-09-2024, 07:02 PM
Last Post: britelite
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 995 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 3,422 09-01-2023, 04:26 AM
Last Post: gregb49
  US Cell Phone Service Providers with prices and phone numbers - UPDATED jovval 0 680 07-01-2023, 01:25 AM
Last Post: jovval
  SD Card has wrong capacity AndyM 11 2,128 06-11-2023, 12:30 AM
Last Post: AndyM
  Loving my pine phone after about a year of not undata 0 656 05-11-2023, 02:23 PM
Last Post: undata
  New Phone Opening Issues LuluFrance 5 2,029 03-15-2023, 05:33 AM
Last Post: anonymous
