Disable the Power Button or make it do something else
Loving the Pinebook Pro on i3 Manjaro, but the power button is too close to the backspace and I keep hitting it.
I've tried the two things in this guide: https://forum.pine64.org/showthread.php?...wer+button
1. Editing the logind.conf file
2.  this fancy commmand : systemd-inhibit --what=handle-power-key --who=i3 --why="accidental strike defense" sleep infinity
Neither of these two things worked and I've not found a solution on the manjaro forum.
Any advice?
Hi, dont know for i3, on sway i did :
1/ inhibit powerbutton in systemd/logind.conf
HandlePowerKey=ignore
2/ sway/config
# power button
bindsym XF86PowerOff exec ~/bin/wayland_toggle_screen.sh
3/ with wayland_toggle_screen.sh :
#!/bin/sh
read lcd < /tmp/lcd
if [ "$lcd" -eq "0" ]; then
swaymsg "output * dpms on"
echo 1 > /tmp/lcd
else
swaymsg "output * dpms off"
echo 0 > /tmp/lcd
fi
it works nice (powerbutton does switch screen on/off)
(05-30-2021, 10:35 PM)rimaille Wrote: Hi, dont know for i3, on sway i did :
2/ sway/config
# power button
#!/bin/sh
read lcd < /tmp/lcd
        echo 1 > /tmp/lcd
    else
        echo 0 > /tmp/lcd
    fi
Hi. I did 1 and for 2 I added this line to the shutdown code:
# Set shut down, restart and locking features
bindsym $mod+0 mode "$mode_system"
bindsym XF86PowerOff mode "$mode_system"
My only thought is maybe its a different key code on ANSI keyboard?
(06-01-2021, 01:26 PM)jms429 Wrote: Hi. I did 1 and for 2 I added this line to the shutdown code:
Your response is quite incomplete.
Does 1 (inhibit power button) works ? after editing logind.conf, systemctl restart systemd-logind.service, or reboot.
Does your bind mod+0 works ? If it doesnt, not a problem of keycode, but code, in your conf.
Assuming you use i3, you must use x11, so try use xev to get your keycodes (mine is ansi too).
You are right, I wasn't helping with the lack of info.
1 (inhibit power button) didn't work, mod+0 worked fine.
Today, I added HandleSuspendKey=ignore and HandleHibernateKey=ignore to logind.conf then ran systemctl restart systemd-logind.service
and it is now working fine. Not sure if it is the extra entries, or restarting the service that did it.
instead of modifying logind.conf you can use https://www.linux.org/docs/man1/systemd-inhibit.html to take the lock on the handlepowerkey.
So that when sway is running the powerkey is inhibited and when it is stopped it isnt.
i disable the power button via systemd and bind wlogout to sway exit.
  Unable to make a bootable microSD card myself600 15 5,163 09-27-2022, 01:45 PM
Last Post: myself600
  Loud distorted speaker sound when connecting to power supply myself600 2 1,121 09-21-2022, 12:11 PM
  How to make manjaro sleep or hibernate? KDE? regretfulpineuser 0 937 06-20-2022, 12:56 AM
Last Post: regretfulpineuser
  red/green power led not working with kernel 5.14 alchemist 4 3,675 11-04-2021, 04:09 AM
Last Post: alchemist
  Power LED flashing red/green... appelgriebsch 3 4,993 09-05-2021, 07:59 PM
Last Post: dealie
Question How do I disable autologin on TwisterOS? TDC_PBP 3 3,262 08-27-2021, 11:44 AM
Last Post: TDC_PBP
  Pinebook Pro Manjaro Power Savinng Tips HelpMyBatteryIsDraining 1 2,391 06-15-2021, 08:42 AM
Last Post: moonwalkers
  Make it easy? wdt 0 1,657 09-10-2020, 10:05 PM
Information How to make the Manjaro Gnome image update TDC_PBP 2 4,230 07-13-2020, 02:24 PM
Last Post: TDC_PBP
  power button bsammon 3 4,494 03-25-2020, 02:20 PM
Last Post: bsammon
