SSH From Outside LAN not working
Hi all. Not sure how many of you have tried to SSH into your pine64 (using debian image) from outside of the LAN. I am unable to do so. Here are some things I have discovered to help.
1. I have a Raspberry Pi that I can SSH into from the outside. I have a router/modem combo from COX and can SSH from the outside and inside the LAN just fine. And strange enough, I don't even have to forward any ports to do this.
2. I tried to open the port on the router and looks like that doesn't matter one way or another.
3. When the RPi is plugged in to the router/modem, when I check the port 22 on a website, I enter my outside LAN IP and scan port 22 opens. When I remove the RPi and scan again port 22 closes.
4. With the pine64, I have the SSH setup. I can ssh to it from inside my lan network. Can't access outside my LAN.
5. Ran nmap
sudo nmap -p22 **outside LAN IP**
 on my pine64 and it says port 22 is filtered. Now I haven't checked if it says open with RPi only attached to the router/modem but will try that.
6. Ran tcpdump
tcpdump -i eth0 port 22 -n -Q inout
and it doesn't even detect traffic at all, so then I think it's a router issue.
I'm trying every trick I can think of. Anyone have some ideas as to what is going on? If you need more info, just ask! Thanks for the help in advance!
  Ctrl + Shift + Tab not working in Firefox Bolitoglossa 2 4,106 08-21-2020, 04:05 AM
Last Post: Bolitoglossa
  Input not working after a forced shutdown dic1911 1 3,461 12-24-2018, 07:45 PM
  Any success working with OpenCV on the PineA64? Tonny91 0 2,446 10-16-2018, 09:16 PM
Last Post: Tonny91
  Mini-Tutorial to get a linux Desktop GUI working on Pine64+ speedro86 15 26,578 04-05-2017, 01:45 PM
Last Post: speedro86
  RESOLVED - LCD screen not working, HDMI does asuras 10 15,905 04-02-2017, 08:12 AM
Last Post: Luke
  Getting z-wave module working under ubuntu marcosti 6 11,934 02-10-2017, 07:53 AM
Last Post: JamesWatt
  Is the Wifi module working? clawinus 8 10,633 11-23-2016, 10:09 AM
Last Post: clawinus
  Any luck getting JACK working on the pine64? tampadave 1 3,432 09-23-2016, 06:54 PM
Last Post: pfeerick
  Pine 64 IR Receiver not working rajatgarg21 1 3,185 08-31-2016, 12:47 AM
Last Post: MarkHaysHarris777
  Remote Not Working? mesaxi 2 4,195 06-30-2016, 04:59 PM
Last Post: mesaxi
