Battery mot charging past 54%
#31
(01-14-2022, 08:29 AM)kqlnut Wrote:
(01-14-2022, 04:49 AM)vusra Wrote: It charges to 100%, then it discharges to 93 - 95%... then charges again to 100% ... repeat... sounds bad for the battery left on the charger long term. Can a maximum charge limit be set?
See megous' comment a couple of posts before for an explanation. And yes, a maximum limit can be set and is set already on many distros (what is displayed in the battery indicator as 100% may not be the real 100% capacity the battery has). Check out the PostmarketOS tweaks app for a GUI to change that (not only available on PostmarketOS).
PostmarketOS tweaks  battery limit setting does not work in Debian.  The setting change returns to 4.20V after opening PostmarketOS tweaks again.
What you are describing is the normal float charge pattern, to hold the phone near 100%
Some of the distributions are adding apps that allow the user to easily adjust their own charging patterns.
I don't think This is harming my battery,  ...
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
PostmarketOS tweaks in mobian offers changing the maximum charge level. It is not functioning. The setting change returns to 90% 4.20V after opening PostmarketOS tweaks again.
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 487 02-17-2024, 04:15 PM
Last Post: vortex
  Battery life improvement freelectro 10 3,188 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,485 03-20-2023, 12:54 AM
Last Post: bcoyle
  Charging Indicator On - Not Charging SJSEng 0 767 08-30-2022, 07:33 AM
Last Post: SJSEng
  Power supply vs battery albafrati 11 4,521 06-22-2022, 06:04 PM
Last Post: albafrati
  PPKB with phone; phone dies while charging SwordfishII 1 1,349 06-08-2022, 04:14 AM
Last Post: SwordfishII
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 1,436 04-28-2022, 12:45 PM
Last Post: james8880
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 3,973 03-08-2022, 12:25 PM
Last Post: jopple
  Battery replacement alternative sax1960 7 6,241 08-29-2021, 07:03 AM
Last Post: bcnaz
  Battery Capacity and Software Interaction food 2 2,401 08-15-2021, 07:19 AM
Last Post: bcnaz
