Compile spacebar
I'm on a updated manjaro image that came with the pinephone beta edition.
I'm trying to get spacebar to compile.  To help fix some bugs in this thing.
It has a required library called libqofono . But when I go to install it on a mostly stock system it complains about existing files in the install directory.
libqofono: /usr/share/qt5/mkspecs/features/qofono-qt5.prf exists in filesystem (owned by libqofono-qt5)
And many others.
Was this library compile and installed with make install manually on the shipped image? I'm not sure how to proceed from this.
(05-14-2021, 08:37 AM)wizardofthemodem Wrote: I'm on a updated manjaro image that came with the pinephone beta edition.
And many others.
I got it to compile. Had to install the kirigami2 requirements.
sudo pacman -Syu base-devel extra-cmake-modules cmake kirigami2 kde-sdk-meta gettext
Takes forever to build on the pinephone. Not sure how to install it and test it yet.
https://invent.kde.org/plasma-mobile/spa...equests/24
check it out linux phone friends, Made my first PR into spacebar.  Anyone know someone from kde that can code review it?
  Brief overview on help to use uboot/usb serial and compile a kernel davegermiquet 1 3,020 06-22-2020, 01:27 PM
Last Post: doniks
