Cant update and upgrade mobian.
Hello , I have problem.
I cant update and upgrade Mobian.
In terminal write
Reading package lists... Error!
E: flAbsPath on /var/lib/dpkg/status failed - realpath (2: No such file or directory)
E: Could not open file  - open (2: No such file or directory)
E: Problem opening
E: The package lists or status file could not be parsed or opened.
is it a fresh install?
(05-04-2021, 02:21 PM)vongillus Wrote: Hello,
No, I install about 1,5 month ago.
You should be able to refresh the apt lists by:
1 Make a backup of your apt lists
sudo cp -R /var/lib/apt/lists/* ~/lists/
2 Remove apt lists
sudo rm -R /var/lib/apt/lists/*
3 Repopulate
sudo apt-get update
Cheers!
(05-04-2021, 09:16 PM)MtnSk8 Wrote: You should be able to refresh the apt lists by:
2 Remove apt lists
3 Repopulate
sudo apt-get update
Cheers!
Thanks.
(05-04-2021, 02:13 PM)mode80 Wrote: Hello , I have problem.
In terminal write
E: Problem opening
Be aware, there was a defect in the boot partition around the time frame you did your installation where you would run out of space and no longer be able to update. Sooner or later you may need to do a fresh installation to fix the problem. Follow the blog. https://blog.mobian-project.org/posts/20...021-03-17/
Now I have a similar problem with the latest Mobian release flashed onto my PinePhone's eMMC
Unable to update "OS Updates":
Prepared update not found: /var/lib/PackageKit/prepared-upgrade
wcdeich4@hotmail.com
Where you able to solve this problem? I am having the same issue.
(12-24-2021, 09:23 PM)wcdeich4@hotmail.com Wrote: Now I have a similar problem with the latest Mobian release flashed onto my PinePhone's eMMC
I see the same notice on occasion, but I think it has to do with the "update Cache",
Sometimes the updates appear before they are released. (?)
I update my daily driver with the Mobian OS every day, I DO see this happen, but it catches up usually within 24 hours.
(as I have multiple Pinephones, I also have one test phone that I run the latest release of Mobian on a sd card, -- first Nightly, now weekly releases.)
Pine would not exist without these great Developers,  but my mission is to prove a GUI User can survive here,
....or at least "Follow along".... with a working phone.  (Talk, Text, data)
It was a quite a challenge back in the Brave Heart days, but it has gotten much easier since then.
...I have had a 'working' Pinephone 99+% of the time since,  and I have never opened a terminal once.
Needing an occasional Restart is not a big deal for me, I hear Android users and iphone users scream when they must do a restart.
but all phone operating systems do need a restart on occasion.
Most of this thread is quite "DATED"  and most of the problems listed here are from the past.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Mobian repository status henrythemouse 16 8,744 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 2,002 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 131 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,994 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,819 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,893 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,898 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 630 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,017 06-19-2023, 03:02 PM
Last Post: vusra
