Battery level fluctuating wildly
I started charging with a USB-C PD capable battery bank at 17% battery on PostmarketOS.
The battery level was stuck at 17% for a few minutes before jumping to 50%.
Then it went to 30% and 39% after a few more minutes.
I suspect this is a voltage monitoring issue not a software issue.
Have anyone seen something similar?
Update: I made a while true loop to monitor battery charge level every second. I will report back later.
Update 2: Charge percentage incremented normally after the 40% mark. Currently stuck at 89% for the past hour.
I haven't done any hardware testing with the voltages, but my battery does the same. It never goes above 34% while plugged in, and when it's not plugged in and just running on battery power, it drops immediately to 4% and slowly times to around 20% - but the phone enters a near unusable state.
I'm just running the manjaro/plasma out of the box install, updated before use, but I have no taken much time to mess around with anything else. It looked daily driver ready while it was plugged in but it seems borked when it is not.
I am having a similar battery issue. It was fluctuating wildly during initial charging. It maxed at 86% after being left plugged in during use first day after update. I unplugged and used battery until completely drained at 0%. I fully recharged it with power off after this and it fully charged at 87% and would not go any higher. Seems like a few batteries are not functioning properly.
(05-11-2021, 10:02 PM)Ob1wanatoki Wrote: I am having a similar battery issue. It was fluctuating wildly during initial charging. It maxed at 86% after being left plugged in during use first day after update. I unplugged and used battery until completely drained at 0%. I fully recharged it with power off after this and it fully charged at 87% and would not go any higher. Seems like a few batteries are not functioning properly.
This charging limit is set on purpose for safety reasons. Your battery should be fine.
  Megi's Kernel and Battery Life biketool 3 2,118 01-09-2023, 11:33 PM
Last Post: Canyonless
  PinePhone Pro battery life Barugon 17 15,480 07-29-2022, 09:23 AM
Last Post: prog-amateur
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,519 06-23-2022, 02:44 PM
Last Post: zer0sig
  Phone won't suspend, battery drains quickly nelstomlinson 12 7,161 04-05-2022, 06:11 AM
Last Post: Anna
  The modem switch affects the connection to battery? JohnDoe 2 2,000 03-30-2022, 12:02 AM
Last Post: JohnDoe
  improve battery life on pine phone beta? taoschx 0 1,059 02-28-2022, 06:24 AM
Last Post: taoschx
  Guide to power off the Pinephone on low battery Ulfnic 1 1,545 02-06-2022, 05:16 AM
Last Post: Ulfnic
Question Is there a way to increase the battery life of the PinePhone? Avisando 18 12,184 01-22-2022, 11:55 PM
Last Post: bcnaz
  Battery Charger? JesusGod-Pope666.Info 9 6,437 12-01-2021, 09:00 AM
Last Post: JesusGod-Pope666.Info
  Battery life: Maybe really a hardware issue? KNERD 34 21,602 09-23-2021, 01:11 PM
