Another sudden Pinecil death
I received a pinecil from the latest batch today - sadly it only worked 2 times - once plugged into 20v via DC jack. The other time in a QC3 usb-c socket with a negotiated voltage of 15v.
During heating of a D24 TS-100 tip 8.Ohm@15V via usb-c the OLED screen froze and the buttons became unresponsive. After unplugging and reconnecting the pinecil the screen stayed off. The DFU mode also does not trigger. The pinecil does not show up as a USB device.
Further investigation resulted in the following: the pinecil when supplied with power via USB-c will consume about 120mA. A visual inspection of the pinecils board does not show any obvious damage or soldering faults.  The DC-DC converter (U8) on the board gets hot. The 3v3 regulator (U5) also gets hot. The 5v rail voltage is at ~4.0v. The 3.3v rail appears to be shorted to ground.
A cracked smd cap would explain this short very handily and this matches the accounts of a couple of other posts i saw in here. I already made a ticket in the pine64 system.
Did you get anywhere with support, they just pushed me along to IronOS Discussions on GitHub... I also noticed the bottom of my unit gets hot when plugged into USB (bottom area directly down from the OLED screen)
  Connecting a power supply to the Pinecil jon_bondy 1 333 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 754 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 352 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,175 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 642 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,264 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,525 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,422 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,224 12-14-2022, 01:03 AM
Last Post: River
  Survey on Pinecil Tips, Please fill out River 0 1,240 11-06-2022, 02:43 AM
Last Post: River
