Linphone on Mobian (SIP client)
I just tested today if the standard desktop application Linphone works.
I did a
sudo apt install linphone-desktop
Then started it. Ok first issue: it needs scaling. I am not yet used to scale-to-fit but I did run
scale-to-fit linphone on
. This didn't help. I have tried to find the app id following some instructions but this didn't work. If someone tells me how to find the app id I am ready to update the wiki Smile
So I just tried a general scale-to-fit with the gsettings command and that time it worked! Quite small but I could add my SIP account and I could make a call. Only issue is that I couldn't hear my partner but one could hear me. I have to check this but this looks quite promising!!
  Mobian repository status henrythemouse 16 8,724 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,997 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 131 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,988 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,809 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 632 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,877 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,896 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 628 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,013 06-19-2023, 03:02 PM
Last Post: vusra
