Battery charge threshold
Is there any way to set battery charge threshold to something like 80% or so?
For example, ThinkPads have such option to set battery charge threshold:
echo 60 > /sys/devices/platform/smapi/BAT0/stop_charge_thresh
I did not see similar options for the Pinebook Pro, so I tried to search in the arch/arm64/boot/dts/rockchip/rk3399-pinebook-pro.dts kernel file, but the only thing close to a battery charge limit I've found was this:
charge-full-design-microamp-hours = <9800000>;
I guess I could lower it and probably achieve such effect, but maybe there is a better solution than lying to the system about the actual battery design full charge?
I'm interested in this too. I had previously looked into it and was convinced it's a hardware feature that is unusual. Seems silly when it's well known that batteries live longer with charge limits and there are phone apps that do it.
  Battery gauge issue (mainline kernel) lfourquaux 4 4,848 05-22-2021, 02:43 PM
Last Post: jiyong
  eMMC frequently not found by Linux kernel (especially on low battery) v-man 14 16,168 05-14-2021, 01:18 PM
Last Post: djhnsn
Question Manjaro arm + sway - battery indicator broken mfashby 6 6,577 02-20-2021, 04:07 AM
Last Post: mfashby
  Possible battery and performance improvement xehartnort 4 5,483 11-09-2020, 12:26 AM
Last Post: rimaille
  Manjaro - No battery info after plugged in AlecM 4 5,939 09-16-2020, 08:34 PM
Last Post: zer0sig
  get battery status on the command line rossk 2 5,019 04-04-2020, 09:25 PM
Last Post: rossk
  i3status issues reading battery status dummy 9 11,297 01-31-2020, 08:27 AM
Last Post: C_Elegans
