NVMe SSD and battery life?
If I keep /boot on the eMMC and put everything else on an NVMe SSD drive how much battery life am I going to loose?
It depends on how much power the SSD is using. There are ways to limit the power using the nvme command. I think in my case it's about a couple hours of use time.
Some more thoughts:
https://forum.pine64.org/showthread.php?...3#pid83373
Since that time I've also converted it to the f2fs file system, I don't see any improvement over ext4 in benchmarks or otherwise but it's been quite stable and resilient to corruption so I'm not rushing to change back. I keep the boot partition in the emmc, like you propose in the OP.
(04-10-2021, 03:16 PM)slyecho Wrote: It depends on how much power the SSD is using. There are ways to limit the power using the nvme command. I think in my case it's about a couple hours of use time.
Some more thoughts:
Loosing a couple of hours seems like a shame.  One of the things I love about this laptop is its long battery life.
Is there any risk of wearing out the built in eMMC drive?  I just had an SSD failure on my work Lenovo T470.  Having only /boot on the eMMC means that it's never going to wear out I guess.
interesting article on SSDs and battery life here https://www.tweaktown.com/articles/8856/...index.html
Why I still keep using the SSD:
  1. It's still a lot faster
  2. It has tons of space
These two things combined also allow me to actually use a large swap partition (8GB) because the computer has relatively little RAM.
I wouldn't be concerned about the longevity of the eMMC, it's perfectly useable and faster than an SD card. I have some other tablets that have eMMC storage and they have lasted for years.
It's also not soldered on, Pine 64 sell the modules separately and you can replace them very easily if it should fail.
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 739 09-27-2023, 08:53 PM
Last Post: pinemouth
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 783 07-13-2023, 01:50 PM
Last Post: PaulQ
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,465 04-23-2023, 06:58 AM
Last Post: acruhl
  Pinebook Pro drains ny battery after shutting it off Tongman 4 2,110 12-01-2022, 02:50 AM
  Battery Frost1776 1 1,036 10-07-2022, 04:17 PM
Last Post: LivingLinux
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 125 214,066 09-27-2022, 07:41 AM
Last Post: olyavi
  Pinebook Pro freezes when running on battery petaramesh 5 2,529 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 2,253 09-09-2022, 08:13 PM
  Selling Pinebook Pro (ISO) + nvme from Sweden DavidL 5 3,160 06-20-2022, 03:20 PM
Last Post: DavidL
  For Sale: Pinebook Pro 64gb ANSI with NVMe Adapter Lumat 2 2,034 04-24-2022, 01:42 AM
Last Post: kylexd
