The RK3399 Overclock/Undervolt/Voltages Thread
#31
Stock 4xA53@1416Mhz / 2xA72@1800Mhz / CCI-500@600Mhz
==> Finished making: linux 5.12.9-99 (Sun 06 Jun 2021 03:34:10 CEST)
real 238m40.465s
user 1176m57.838s
sys 82m22.896s
PinebookPro v2.1 4xA53@1704Mhz / 2xA72@2208Mhz / GPU@1125Mhz / CCI-500@1200Mhz
So, it's 238 vs. 213 minutes, or about 10% faster with the overclock.  It must be that the microSD card is a bottleneck. Smile
one funny thing i found out changing the SD bus clock... if i start the laptop with the sd inserted i get this bus speed:
cat /sys/kernel/debug/mmc1/ios
clock:          50000000 Hz
actual clock:  50000000 Hz
vdd:            18 (3.0 ~ 3.1 V)
bus mode:      2 (push-pull)
chip select:    0 (don't care)
power mode:    2 (on)
bus width:      2 (4 bits)
timing spec:    2 (sd high-speed)
signal voltage: 0 (3.30 V)
driver type:    0 (driver type B)
with and average read rate of 21.2MB/s and an average latency of 0.73msec
simply by reinserting the sd after the login a get this:
clock:          200000000 Hz  (150000000 is the default max clock)
actual clock:  200000000 Hz
power mode:    2 (on)
timing spec:    6 (sd uhs SDR104)
signal voltage: 1 (1.80 V)
58.6MB/s Read (peaks of 80MB/s) and 0.57msec Latency
That's very interesting!  It may be related to the issue with A1-rated microSD cards that I've described in this forum thread.
(06-06-2021, 12:15 AM)dsimic Wrote: That's very interesting!  It may be related to the issue with A1-rated microSD cards that I've described in this forum thread.
do you have the same problem? SD running at 50000000Hz, and runs at 150000000Hz only if the SD is connected after the bootup
[Image: PXL-20210609-181329852.jpg]
[Image: PXL-20210609-181622480.jpg]
(06-07-2021, 03:09 PM)generaleramon Wrote: do you have the same problem? SD running at 50000000Hz, and runs at 150000000Hz only if the SD is connected after the bootup
In my case, an A1-rated Kingston microSD card fails to work at SDR104 speed, but limiting the speed of the MMC interface to SDR50, which still runs at 1.8 V, makes the same microSD card work just fine.  The card itself is fine, it works as expected in an external USB 3.0 card reader.
(06-09-2021, 10:29 AM)generaleramon Wrote: [Image: PXL-20210609-181622480.jpg]
This is getting radical, you've hacked off a portion of the RF can shield. Smile  If this doesn't make the BQ24171 cool, nothing else will. Cool
  serial cable 2023 thread bsammon 2 1,195 07-20-2023, 10:13 AM
Last Post: bsammon
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,420 05-20-2023, 01:02 AM
Last Post: jackwilson
  1000th thread KidTechnical 0 682 12-20-2022, 09:26 AM
Last Post: KidTechnical
Wink Booting Windows on bare-metal rk3399 SBC (no linux involved) strongtz 9 10,468 05-26-2022, 11:36 PM
Last Post: strongtz
  Is it possible to overclock Nonetrix 13 16,536 12-04-2020, 07:31 AM
Last Post: dsimic
