Why use x000 mAh instead of x Ah in battery specs? Why no use Coulombs, (SI)?
I understand it is what market does, but aren't we a "nerd" community.
Al least instead of writing 3000 mAh write 3 Ah for the Pine phone battery
And even better 3 Ah / 10800 C.
Even from a marketing point of view 10800 C is perceived as more than 3000 mAh or 3 Ah even it is the same.
And I would use kC as 10.8 kC for this case.
  Megi's Kernel and Battery Life biketool 3 2,120 01-09-2023, 11:33 PM
Last Post: Canyonless
  PinePhone Pro battery life Barugon 17 15,489 07-29-2022, 09:23 AM
Last Post: prog-amateur
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,519 06-23-2022, 02:44 PM
Last Post: zer0sig
  Phone won't suspend, battery drains quickly nelstomlinson 12 7,174 04-05-2022, 06:11 AM
Last Post: Anna
  The modem switch affects the connection to battery? JohnDoe 2 2,004 03-30-2022, 12:02 AM
Last Post: JohnDoe
  improve battery life on pine phone beta? taoschx 0 1,061 02-28-2022, 06:24 AM
Last Post: taoschx
  Guide to power off the Pinephone on low battery Ulfnic 1 1,547 02-06-2022, 05:16 AM
Last Post: Ulfnic
Question Is there a way to increase the battery life of the PinePhone? Avisando 18 12,187 01-22-2022, 11:55 PM
Last Post: bcnaz
  Battery Charger? JesusGod-Pope666.Info 9 6,442 12-01-2021, 09:00 AM
Last Post: JesusGod-Pope666.Info
  pinephone 2 specs discussion - 5G WiFi6 BT5 NFC? - mitcoes 17 16,651 10-08-2021, 07:50 PM
Last Post: zetabeta
