Issues with Mobian 20210314 (data and updates)
used for a while Plasma KDE (still too buggy, for me) and Phosh OS (working fine) and now decided to give Mobian (20210314) a try (on this forum, it is highly appreciated). So, flashed a SD with it.
Unfortunately, data download never started working (although, I have the 4G symbol activated and four bars). Of course, set the APN.
Calling works fine, SMS works (but no audio signal and light blinking when I got the message) and WI-FI works as well but, oddly, using it, my phone is unable to download updates ("The following packages have unmet dependencies").
Any help for the two issues?
Many thanks.
Hi there - I would try get the mods to move this to the PinePhone/Mobian forum!
(03-16-2021, 03:20 AM)IMSAI8080 Wrote: ..
Under Settings, Mobile do you have Mobile Data enabled?
(03-16-2021, 03:20 AM)IMSAI8080 Wrote: ...
In general I don't get that with Mobian - it means apt has got its knickers in a twist which is a generic Debian issue you can ask Prof Duckduckgo about. But on the basis it is uncommon in Mobian I would recommend doing your download/flash again in case something is corrupt there.
Ops... wrong forum, sorry for the oversight.
Anyway, thanks dukla2000 for your answer and... yes, data enabled.
Asked Prof. Duckduckgo, before posting the tread: the steps suggested to fix the problem require an OS update, after the terminal work.
That's why I wrote about the updating issue in the same thread.
Think that the easier way for me is to reflash the SD and hope for the best.
Ciao
PS: moving the chat above to the right forum: how, coping and paste?
(03-16-2021, 12:26 PM)IMSAI8080 Wrote: PS: moving the chat above to the right forum: how, coping and paste?
I just moved it... carry on...
Ciao
Have you read this mobian blogpost?
https://blog.mobian-project.org/posts/20...pam_issue/
There they write:
Quote:You will get some mysterious “Cannot update due to unmet dependencies” error in the software app if you try. So for the initial update, we recommend performing a manual update in the terminal (a great way to familiarize yourself with the terminal and Debian’s package manager called apt).
For this drop into the terminal King’s Cross (also called kgx, it has a subway logo). On the terminal issue:
sudo apt update
sudo apt dist-upgrade
sudo apt autoremove
Ciao
There they write:
sudo apt update
sudo apt autoremove
That's great, actually, I'll take a note, for the future!
Anyway, after downloading/flashing my SD again, as suggested, everything is working fine.
The OS immage was corrupted, indeed.
Problem solved Smile
Thanks again for your help!
Ciao
  Mobian repository status henrythemouse 16 8,591 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,862 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 118 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,904 11-22-2023, 11:46 AM
Last Post: aLoop100o
  No volume control after latest updates Zebulon Walton 19 6,960 09-08-2023, 08:28 AM
Last Post: jessencan
  What actions needed to keep on mobian testing user641 3 1,774 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 620 09-01-2023, 11:29 AM
Last Post: Mahgue
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,273 08-31-2023, 12:38 PM
Last Post: vusra
  how to update mobian over tor vusra 13 6,815 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,877 07-09-2023, 01:37 AM
Last Post: vusra
