Will It Be Okay To Order The PineBook Pro US Version For Use In The UK?
Hi
Is it okay to order the US version of the PineBook Pro for use in the UK? The different keyboard layout doesn't bother me, I just wanted to know if there's anything else I should be aware of? For instance maybe voltage issues?
The only issue you might experience in the UK is being unable to use the DC adapter without a wall plug adapter.  The shipped DC adapter actually supports interchangeable wall plugs, but gets shipped with only one wall plug.
(03-15-2021, 02:27 PM)dsimic Wrote: The only issue you might experience in the UK is being unable to use the DC adapter without a wall plug adapter.  The shipped DC adapter actually supports interchangeable wall plugs, but gets shipped with only one wall plug.
But it can still charge through USB-C though?
Yes, it can, although there are some issues with the amount of power the PineBook Pro is capable of taking from any of its two power inputs (the barrel jack and the USB Type-C port).  Please, have a look at this thread as well.
My ANSI PBP came with a UK and a US plug. I can't be certain, but I think both of the ones I bought did. So you might get the correct plug anyway. If not, it should be easy to get one.
That's interesting.  My ANSI variant of the PineBook Pro came with an EU plug only.
I thought it was strange. I might have saved the second one just because I hate to throw things like that out, but there's zero chance of me ever needing it.
Quite frankly, one of the very few things I have really no regrets about throwing into garbage is a UK wall plug adapter or a UK wall wart. Big Grin  No offense to anyone, it's just that I absolutely don't need them and they take up a lot of space.
  Pinebook Pro Initial Impressions kunger 441 583,312 3 hours ago
Last Post: Tazdevl
  looking to buy one pinebook pro (mainland China) duanduan 3 2,228 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 371 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 275 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 267 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 203 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 628 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 693 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,446 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,155 12-15-2023, 02:11 PM
