WiFi - Can see networks, not connecting
I got my Pine A64 last week, and today I finally unpacked it.
I connected the BT/WiFi module, plugged in a monitor and a keyboard and booted up the Android build supplied in the box.
Everything booted nice and fast. I went into the settings, enabled WiFi and selected my home network. I was able to see all surrounding networks  (not our high speed 5GHz access point but the older 2.4GHz showed up fine), so I entered the password and hit connect.
I very briefly saw first "Connecting...", followed by "Authenticating" and then "Saved". It never said connected.
I double and triple checked the password (I know it very well), I turned wifi off and on again, tried to reconnect... Nothing.
I tried entering a static IP address instead of using DHCP. Still nothing.
Anyone have an idea what to do? The BT part seems to be working, at least it can see different devices. I haven't tried to actually connect to any.
I have tried with both BT on and off.
Update: Eventually I got a status message saying "WiFi Connectivity Failed" or something similar.
Update 2: I enabled wifi hotspot on my mobile phone, and then it connected fine, bot when I set it up as Open and using WEP2 PSK. So it seems to be a problem with my router (from Time-Warner). I guess that is a project for tomorrow...
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,903 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Cannot charge and NO Wifi? jiapei100 3 5,468 06-27-2020, 02:11 PM
Last Post: jiapei100
Bug WiFi enabled but refuses to connect cardboardmaster 6 7,799 06-02-2020, 11:56 PM
Last Post: pfeerick
  WiFi issues Pinebook Pro sunnystormy 6 9,048 05-28-2020, 05:44 PM
Last Post: Luke
  wifi issues george2524 9 10,811 06-13-2019, 04:25 PM
Last Post: evilbunny
  Is the Wifi module working? clawinus 8 10,680 11-23-2016, 10:09 AM
Last Post: clawinus
  how to install Wifi/Bluetooth module danlcarr 2 4,264 10-08-2016, 09:59 PM
Last Post: danlcarr
  WiFi module causes boot loop BnEc 17 25,531 09-24-2016, 09:12 PM
Last Post: pfeerick
  LCD works only when Wifi Module not installed nesalot 2 4,557 09-03-2016, 03:53 AM
Last Post: nesalot
  Wifi 802.11BGN/ Bluetooth 4.0 Module jesse1234 1 3,154 07-26-2016, 11:26 AM
Last Post: MarkHaysHarris777
