New Mobian Pinephone
Just got my phone in yesterday.
I got it fired up and charged. Connected to my wifi.
I know this is a work in progress, but my battery seems to last less than an hour.
I tried to look at the software updates, and it just has a spinning ring or freezes.
What's my next step?
(03-11-2021, 04:07 PM)czgunner Wrote: What's my next step?
 This is a good guide (assuming you have the mobian ce edition):
https://blog.mobian-project.org/posts/20...pam_issue/
Cheers!
Perfect. Trying that now. Thanks!
The software tool was broken for me when I first installed it back in January. Command line updates with "full-upgrade" fixed that.
Also possible that something is causing a massive CPU load issue. You may want to look at it to see if things are running idle. "top" over SSH for me is always only a small 1/10th of a percent CPU usage with the screen off.
I do mostly keep the radio off for most of what I'm doing (docked) but I have run Podcasts while clearing the snow outside w/ radio enabled and it's clearly not even close to my Android but should last more than an hour of actual use.
Got the update installed. Seems much more smooth. Also, the battery seems to be better. Charging now. Thanks for all the help!
  Mobian repository status henrythemouse 16 8,743 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 2,002 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 131 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,630 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,994 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,819 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,888 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,898 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 630 07-05-2023, 03:57 AM
Last Post: paulcarton
