Pine Phone Battery Issue
#21
(03-30-2021, 12:04 PM)Zebulon Walton Wrote:
(03-27-2021, 01:12 AM)Gribouille Wrote:
(03-26-2021, 03:18 PM)Zebulon Walton Wrote: I bought a compatible battery from eBay for about $6 with free shipping and it works fine. You want a Samsung EB-BJ700BBC battery for a Galaxy J7.
https://www.ebay.com/itm/3000mAh-Battery...3865335933
Thank you @Zebulon Walton  Smile
This is a precious information !
You're welcome! The only issue I ran into is that battery had a plastic molding glued to the bottom edge (opposite edge from the contacts) that had to be removed for it to fit in the phone.
@Zebulon Walton
  In the wiki they give a few different part numbers,  This is the one I purchased on ebay,
       It fits perfect without any trimming.
 "For Samsung Galaxy J7 SM-J700 J700M J700P J700F EB-BJ700 CBE"
Only difference I noticed is the Pine battery is rated 2800 mAh,
the Samsung is rated at 3000 mAh,  very close.
I also just started playing with the "'external Pine phone battery charger"' I bought last year,
but I just started using that when my new battery arrived.
That charges the battery much faster even though I am powering it with the same wall charger.
  When the red LED indicator light goes out and you install the battery into the phone it reads
   100% charged.
   ( But then that is only charging the battery and not also powering the phone. )
NeF
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
if you set the maximum current in the /sys which I think is 3A then it will be charging much faster minus the consumption
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 365 02-17-2024, 04:15 PM
Last Post: vortex
  Phone will not turn on (but sometimes will) insidetrip101 10 4,378 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 916 07-31-2023, 07:50 PM
  Battery life improvement freelectro 10 2,944 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,412 03-20-2023, 12:54 AM
Last Post: bcoyle
  No calls on Pine Phone Beta convergence edition polypode 1 1,108 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 1,052 02-20-2023, 12:14 AM
Bug DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time e1337 11 4,098 01-26-2023, 10:11 PM
Last Post: AnAbolitionist
Thumbs Down Phone is unresponsive theneedful 14 7,189 08-12-2022, 08:18 AM
Last Post: theneedful
  Phone Dead Already? MarsColonist 4 2,548 08-11-2022, 11:52 AM
Last Post: auanta
