USB Ethernet support
Anyone know if there is a USB Ethernet device that is supported by Pine64/Debian?  I am looking to setup a firewall/router with mine, and would like to have 2 actual ethernet ports as opposed to using one port and setting up VLANs.  Thanks....
It should, I have Ubuntu installed on my Tegra K1 Chromebook and it works fine with the monoprice usb ethernet adapter I have.
Ill try it on the Pine64(Ubuntu), tonight and report back for you.
I got the TRENDnet USB 3.0 to Gigabit Ethernet adapter. Haven't tried it with Linux but Android doesn't ''see'' it at all.
Under Linux if you edit ''interfaces'' it might work but on Android none of its 2 LEDs even blink when I connect it.
(06-10-2016, 06:38 AM)pleco Wrote: Anyone know if there is a USB Ethernet device that is supported by Pine64/Debian?  I am looking to setup a firewall/router with mine, and would like to have 2 actual ethernet ports as opposed to using one port and setting up VLANs.  Thanks....
Couldn't get my monoprice usb adapter to work on the minimal install.  Its possible that it may work on Unity, but I'm not going to install it.  On my Tegra-K1 laptop running Ubuntu's Unity it does work though.
you may need to install the firmware packages via apt-get on Ubuntu. On the Debian images include them by default in order to support as many devices with much tinkering for new users.
can you post the results of lsusb here. I can narrow down what neeeds to be installed Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
  Programming languages support under PINE64 baryluk 6 12,299 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 2,910 12-06-2018, 01:14 AM
Last Post: tenspd137
  AXP803 Battery Charger Support xalius 14 24,079 12-22-2017, 08:59 AM
Last Post: Velociraptor
Wink Pine64 Will support Freenas or openmediavault ? joe 1 4,967 04-13-2017, 07:44 AM
Last Post: xalius
Question No more ethernet with linux... Android connection is fine?!?! cr2016 9 12,383 11-12-2016, 07:29 PM
Last Post: cr2016
  Remote Desktop Support? Rochambeaux 20 29,227 10-01-2016, 05:08 PM
Last Post: HayseedGeek
  Binfmt_misc support cztian 1 3,697 08-17-2016, 11:49 PM
Last Post: longsleep
Question Joystick/Gamepad support Drakuwa 3 5,974 08-10-2016, 10:12 AM
Last Post: xalius
Big Grin Funny ! Support Intel x86 linux applications on ARM-based ( PINE64 ) not freeware joe 10 16,381 08-09-2016, 05:59 PM
Last Post: dkryder
  Camera support - Ubuntu Xenial 16.04 LTS @lex 3 5,212 08-07-2016, 03:47 AM
Last Post: romansavrulin
