Suggestion: PinePower 120W - fix USB port orientation
The USB specification actually specifies how the USB-A ports should be oriented. But PinePower 120W does not follow this (at least now). So it would be really nice to fix it in the next revision of PCB and rotate the ports by 180 degrees ;-)
In early days of USB, manufacturers of devices were using both correct and incorrect orientations. So it was really difficult to plug in the cables for the first time. Fortunately, I have not seen a device with the wrong orientation in last few years. So I was able to look like a "real wizard" by always connecting USBs on the first try :-) Well at least until today, when I received PinePower 120W and my OCD kicked in.
I did not find any mention of this issue anywhere, so starting new thread... Sorry if this is already known thing.
(02-23-2021, 07:17 PM)had Wrote: The USB specification actually specifies how the USB-A ports should be oriented. But PinePower 120W does not follow this (at least now). So it would be really nice to fix it in the next revision of PCB and rotate the ports by 180 degrees ;-)
strongly agree :-) only recently I had discovered that there was a standard orientation and was so happy with this... all I had to do is to look at the male USB-A plug and put the plastic side downward... easy to remember after all: the "earth" down and the "air" up :-))) then my PinePower arrived and wiped out all my certainties :-))
  Suggestion for the Store Tourma 3 805 11-02-2023, 12:46 PM
Last Post: diederik
  PinePower 120w On/Off Switch rohtua 7 5,579 08-01-2023, 05:36 PM
Last Post: Callabra
  PinePower USB-C ports dead nbxmike 1 1,322 01-31-2023, 03:45 PM
Last Post: fxc
  Issues with PinePower Desktop superkamiguru 0 772 10-24-2022, 07:43 AM
Last Post: superkamiguru
  PinePower 65w - DoA or am I doing it wrong? CampGareth 10 8,183 10-04-2022, 09:02 AM
Last Post: hobbitus
  PinePower 120W Screen Issues t-3 3 1,815 09-26-2022, 05:14 PM
  on pinepower, pinecil stopped working.. sanderboer 1 1,114 09-23-2022, 03:47 AM
  PinePower Desktop USB-C port dead qeek 3 1,945 08-29-2022, 12:33 AM
Last Post: gravedigger
  PinePower USBench concept: Usb C universal/lab power supply (=48V5A PD 3.1 trigger) ijsbeer 3 2,989 04-16-2022, 04:59 PM
Last Post: ijsbeer
  Suggestion: PineTV Stickman 10 6,835 01-09-2022, 05:28 PM
Last Post: jasonriedy
