PinePhone Cross Compiler Install
I'm trying to install a GCC cross compiler so I can write so really bad code for when my PhinePhone gets here; a 5th grader is probably a better coder then I am.
Anyway, I'm using these instructions, and it work just fine untill I try to install glibc
https://preshing.com/20141119/how-to-bui...-compiler/
make -j4 csu/subdir_lib
returns this
make[2]: *** [/home/dgdimick/PinePhone/CrossCompiler/build-glibc/sysd-rules:9: /        home/dgdimick/PinePhone/CrossCompiler/build-glibc/csu/libc-start.o] Error 1
make[2]: *** Waiting for unfinished jobs....
check_fds.c: Assembler messages:
check_fds.c:81: Error: no such instruction: `brk '
make[2]: *** [../o-iterator.mk:9: /home/dgdimick/PinePhone/CrossCompiler/build-g        libc/csu/check_fds.o] Error 1
In file included from ../include/errno.h:25,
                from ../csu/libc-tls.c:20,
                from ../sysdeps/aarch64/libc-tls.c:19:
../sysdeps/aarch64/libc-tls.c: In function ‘__tls_get_addr’:
../sysdeps/aarch64/nptl/tls.h:91:19: error: ‘__builtin_thread_pointer’ is not su        pported on this target
  91 |  (((tcbhead_t *) __builtin_thread_pointer ())->dtv)
../sysdeps/aarch64/libc-tls.c:30:16: note: in expansion of macro ‘THREAD_DTV’
  30 |  dtv_t *dtv = THREAD_DTV ();
make[2]: *** [/home/dgdimick/PinePhone/CrossCompiler/build-glibc/sysd-rules:485:        /home/dgdimick/PinePhone/CrossCompiler/build-glibc/csu/libc-tls.o] Error 1
make[2]: Leaving directory '/home/dgdimick/PinePhone/CrossCompiler/glibc-2.29/cs        u'
make[1]: *** [Makefile:258: csu/subdir_lib] Error 2
make[1]: Leaving directory '/home/dgdimick/PinePhone/CrossCompiler/glibc-2.29'
make: *** [Makefile:9: csu/subdir_lib] Error 2
dgdimick@Samba:~/PinePhone/CrossCompiler/build-glibc $
Any ideas? Or am I just doing this wrong, like there's already as package to install?
I'm running on an old laptop that has Ubuntu installed.
I would expect ubuntu to have a packaged crossdevelopment toolchain available - there's gcc-aarch64-linux-gnu at least. It probably depends which distro you're targeting though - for example PostmarketOS has a script that builds its own crossdev environment.
Here's a couple of instruction/discussion pages on cross compilation for Gentoo, maybe you will find these useful or get some direction from reading these:
https://wiki.gentoo.org/wiki/Cross_build_environment
https://forums.gentoo.org/viewtopic-p-8024368.html
  pinephone virtual keyboard aular 4 299 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 198 04-02-2024, 11:50 AM
  install iso from sd card to emmc aular 2 290 03-11-2024, 10:24 PM
  PinePhone - boot from microSD laserpyramid 5 469 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 107,930 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,713 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 571 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,253 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 471 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,631 12-22-2023, 03:44 PM
