Ps3 controller
I was wondering if any one has hooked up a controller to the pine via bluetooth?
Backer #16,783
Do you play STARBOUND? id like to find a good server
I'm currently running the pine a64+ 2gb WiFi/BT with two ps4 controllers connected with BT.
Using sixaxis app for Android (requires root access)
Tarjei, I know you've mentioned before needing root access and sixaxis app for the PS4 controllers. Is this also the case for PS3 controllers? Or any controllers that connect via BT? Or is this specific to PS4?
(06-09-2016, 11:34 AM)montero65 Wrote: Tarjei, I know you've mentioned before needing root access and sixaxis app for the PS4 controllers.  Is this also the case for PS3 controllers?  Or any controllers that connect via BT?  Or is this specific to PS4?
I know it is required for the ps3/4  controllers. I dont know about the other BT-controllers. Sorry.
Lightbulb Xbox 360 controller NOT recognized lawrencejd 0 2,496 04-09-2020, 03:47 PM
Last Post: lawrencejd
  Running UniFi Controller on a Pine A64+ 1Gb board ishwest 7 32,212 07-15-2017, 09:24 AM
Last Post: smills
